Question about Activision Call of Duty Black Ops
Nat type open ps3 - Activision Call of Duty Black Ops
Posted by yan naing on
Joshua Grant
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 99 Answers
Plug PS3 internet cable directly in moden or router
Posted on Aug 04, 2013
How to open nat for ps3 modern warfare3
Hey alldayrobbie,
Check out this forum post that gives step directions and has video details on how to open a locked NAT for PS3.
Good Luck
Jul 29, 2012 | Comtrend 12 Used 5361t Modems
I whant open in ps3
I take it that you want to change NAT type in your PS3. To open NAT type you first need to get port numbers from PS3 people. Once you get the ports check what the IP add on the PS3 is.Once you have this information login to the router interface and punch in the port numbers and the IP add and your NAT type should be open.
Hope this helped.
Jan 23, 2011 | LanTech (HR-114 II) Router
I have an actiontec modem connected to my ps3. When I play call of duty my Nat is moderate. How can I get my Nat set as open?
you should try to get your nat type to say not availible and look on youtube for help
type in help with getting nat type to not availible on ps3
Jan 18, 2011 | Video Game Consoles & Games
How do you open nat type on the ps3 ?
Nat type is actually defined by your isp..(internet service provider) some companies do not actually support gaming and therefore their service is considered "strict" by ps3 standards for multiplayer gaming online. You may have to reconfigure your pc internet security settings on the computer itself...possibly logging into your router/modem. If this is not helpful or u are unsure of how to do this, contact your isp and explain to them you want the nat type changed...basically they will either not be able to at all and then u need a new isp or they can do it in a matter of minutes and ur nat type will change and give u full access to ps3 online within a matter of hours...hope it helps and u get back to gaming!
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
I have a Motorola WR850G i am looking to open my nat type for my ps3 system i also have a DSL Verizon cable modem which i have open the nat type for that now I'm trying to figure out how to open my nat...
If your using a router, you have to ENABLE the UPnp within your router settings. Once enabled your NAT should be OPEN.
If you do not know how to get into your router, you will need to ask someone you trust to do this.
Jul 30, 2010 | Computers & Internet
How do i change my nat type
go on a computer.
1. in the internet address bar type in 192.168.1.1 or routerlogin.net
2. enter admin and password in the fields
3. your now in your routers setup
4. find a setting called nat
5. set it to open instead of secure
this changes your nat type to 2
if that doesnt work
1. login to router as usual, but find a setting called default dmz server
2. enter the IP address of your PS3 as the dmz server (to see what your ps3's ip is go to network > connection settings and have a look.
this should definitley make it a nat 2 - but try the first method
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
How to get your NAT type from strict to open for a ps3. i have tried opening the ports on the router. it still does not change the NAT type
LINKSYS ::::
NAT STRICT
Step 1 : Connect Router - Computer
Step 2 : open Router Setup by typing http://192.168.1.1 on the address bar of internet explorer (Default Password is Admin )
Step 3 : Click Applications and Gaming
Step 4 : Click DMZ
Step 5 : Select Enable and Give the IP Address of the XBOX/PS3/Wii in it
Step 6 : Click Save settings
Step 7 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 8 : Plug the power cord back to the router and wait till the lights are Solid
Step 9 : Turn on the Xbox/PS3/Wii
Step 10 : Test the Connection
let me know if this works
Regards
TOM
Dec 06, 2009 | Linksys Wireless-G WRT54G Router
My PS3 has no NAT Type!!
there is something known as NAT strict that can happen due to many reasons , NAT or network address translator helps in converting the WAN ip address to LAN side IP address or public to private ipaddress . In a case of NAT strict or no NAT type ur PS3 or the router to which you have connected the PS3 is not able to convert the IP address...
Solution: try logging on to the router manager or PS3 settings and enable the NAT ( it would be in a disabled state or DMZ ( de militarized zone ) state )....
If the nat is already enabled Then try to manually configure NAT by opening the port numbers on the router manager or PS3. Port numbers can of UP or TCP protocol depending upon the games ur tyring to play....
If u donno how u do it then contact sony or the people who gave u the router or ur ISP
Feb 18, 2008 | Sony Playstation 3 (PS3) Console
Activision Call of Duty Black Ops Logo
53 people viewed this question
Top Activision Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
