Water Heaters Logo
Posted on Mar 23, 2009
Re: combi boiler.
The water is ok but l have no central heating on a baxi combi se 80 boiler
Anonymous
Level 1:
  • Contributor 30 Answers
  • Posted on Mar 30, 2009
Anonymous
Contributor
Level 1:
Answers
30
Questions
0
Helped
25647
Points
72
If you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Ideal Logic + Combi C30 not firing up.
Isconnect from the hive ,it has been known the hive thrmostat fails on ideal boilers.
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
No hot water...can any1 help i have a baxi combi 80e
check daiphragm, or micro switch best of luck
A trickle of hot water from taps, central heating ok
it sounds like your shut off valve might be bad even though it turns on and off by turing it doesn't mean that the washer is not stuck to the seat and not opening, try replacing the valve
Manual for Baxi Boiler
any merchant will get one mailed out to you
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
COMBI BOILER /CENTRAL HEATING
the boiler should modulate to controll the radiator temperature but the central heating will go off whilst you are drawing hot water
Top Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Water Heater Expert? Answer questions, earn points and help others
