Microsoft Office Excel 2003 for PC Logo
Posted on Mar 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Copy formulas Real Amateur here, I have a grid containing 48 cells from 1 -24, the cells refer to a column that contain a number from 1 -24. The idea of each cell is that the cell containing the number, the cell underneath tells me how many times that number appears in a specified column ie AA33=COUNTIF(H22:H80,"1) and so on across 12 columns and rows. What I am trying to do is to copy the entire grid and move it down the page to another roster and perform the same calcs but obviously on pasted into different rows. Basically change COUNTIF(H22:49,"1") to COUNTIF(H133:H155,"!")
  • slclarkes Mar 23, 2009
    As I said Amateur here
    Lets say COUNTIF(H22:49,"1") is on Row 45 Column AA and I want to move this formula to COUNTIF(H133:H155,"!") Row 100 Column AA.
    The cut and paste works but it still counts my first area when I paste it
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 27, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
199
Points
Adi Sunardy
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 80 Answers
  • Posted on Mar 23, 2009
Adi Sunardy
Expert
Level 2:
Mentor:
Answers
80
Questions
0
Helped
35922
Points
209
It should work if you just copy and paste it. Or select the range of your working area and right click in destination cell and choose paste special. When new window pop up, just choose Formula.
It should work usually, but by any chance you've encountered the problem regarding this. Just let me know...i'll try to help you...
P.S.: If this information was helpful, please rate this solution.
  • Adi Sunardy
    Adi Sunardy Mar 23, 2009
    The copy paste idea should work if the "configuration/size" of your working area is similar.
    Let me show you the analogy:
        Your Working Area (where are the value to be counted) are H22 to H155.
        Your put the formula (=COUNTIF(H22:H49,1)) in cell AA45.
    When you copy paste the formula from AA45 to AA100, the formula will be (=COUNTIF(H77:H104,1)) automatically.
    Can you see "the working area size" that i mean? Can you get the idea?
    If you want to put the formula (=COUNTIF(H133:H155,1)) by copying paste it, you can't do that automatically because the working area is not similar (the size is not equal).
    The first working area are : H22 to H49 which equal to 28 rows, and in the second formula it will be from H133 to H155 which equal to 23 rows.
    But, if the formula could be changed to (=COUNTIF(H133:H158,1)) which is equal to 28 rows of working area, you can try to copy paste the initial formula (=COUNTIF(H22:H49,1) to cell AA156.
    Like that the "configuration/size" of working area will be similar.
    I will fully understand if you have difficulity to understand what i'm trying to say (i'm not an influence english speaker nor writer :)). Sorry for my poor english, just do not hesitate to ask for more if you still need my help.
Cell number sequence
Sequencing is a formula =A1+1. If you insert a cell you can re-s
equence by doing a autofill in the column that contains the sequence number.
i.e.
Cell A1 value= 1
Cell A2 =A1+1 (value will be 2)
If you auto-fill the entire column will sequence:
=A2+1 (value will be 3)
=A3+1
etc.
My MS Excel vlookup function ASCII type table contains both upper case and lower case letters, characters like ( and % or *, and numbers. It seems to return the numerical equivalent of upper case letters...
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
10answers
In Excel adding positive and negative numbers
Yes,
  1. Select the column. (click on top of the column it will select)
  2. Right Click and select Format Cells.
  3. Select Currency in Category then press OK
b6298df.gif Now just type your Numbers i.e. 571 for $571 and -650 for -$650 and sum using the normal way.
That is Select the Cells which you want to SUM and Press Alt+=
This will bring the total just below the selected cells.
Thanks
Iqbal
When i copy a sum formula in excel the first cell does not remain the same it increments by 1. how can I prevent this?
There are 2 types of direct cell references that you can use when you're writing formulas: Relative References & Absolute References.
A Relative Reference is the address of a cell (e.g. A5). When a Relative Reference in a formula is copied from one cell to another, the Reference gets changed automatically. e.g. If you put a formula in cell c5 as A5+1, when you copy this from c5 to c6 the formula A5+1 will automatically change to A6+1.
An Absolute Cell Reference does not change when its copied to another location. As in the example above if the formula in cell C5 is written as $A$5+1, if you copy this formula from C5 to C6 it will remain as $A$5+1 (NOT change to $A$6+1.
The $ sign signifies Absolute, and can be applied to the Row reference, the Column reference, or both Column & Row (as in the example).
Why don't formulas copy from cell to cell?
Step 1
Determine what formula is to be copied and to what location it is to be copied. Carefully consider the cells that are to be referenced in the formula and that they are indeed the cells that contain the information to be acted upon by this formula.
Step 2
Highlight a cell that has the formula in it and click the right mouse button. Select the "Copy" option.
Step 3
Move to the new destination cell for this formula, right click the mouse button and select "Paste."
Step 4
Check the first cell to make sure the correct calculation has been performed. If not, check the formula that appears in the cell that contains the result of the formula that was just copied. Make sure that the formula references the correct cells. If not, correct the formula and then copy the corrected formula to the rest of the cells that should have this formula applied to them.
The only time I have seen this not work is when the cells/pages are protected.
Note:
Some formulas will require references to multiple pages or a workbook. Make sure that the absolute cell address is used for specific numbers and those that are to be applied to subsequent cell addresses are clearly denoted by the use of "$" in the cell address.
Finding the correct row num
You would have to combine the use of 2 functions. The Address and Match funbctions.
Lets say the number you want the address of is located in cell F1 and you have 2 columns of numbers. One colum in Column A and the other in column B. I will give you 2 formulas. The 1st one will return just the row number. The 2nd one will return the cell address.
Option 1: Lets say you just want to know the row reference of the number in cell F1. Place this formula in cell D1. =MATCH(F1,A1:A20)
If you have another column ytou want the row number of, place the formula in lets say cell D2 and change the column references from 'A' to 'B'.
Option 2: If you want the cell reference, place this formula in cell D1 and D2 instead of the firt formula.
=ADDRESS(MATCH(F1,A1:A20,0),1,1,TRUE)
And just like the first option, for the 2nd column, put the formula in D2 and change the column reference 'A' to 'B'.
2answers
Circular reference working how to open excel file
Clicking cancel will invalidate the formulae, circular references refer to the dependant and precedent cells using each other.
Track/ Audit depending on your Excel version to show which formulae is incorrect - or options view, tick show formaulae and remove them.
Lookup,s
If you can move your name column (C) to the first column, you could leverage the VLOOKUP formula pretty easily.
To do this, do the following:
1) Move the C Column to be the A Column, shifting all other columns to the right.
2) (optional) Insert a new row at the top of the sheet (to hold the formula & seach value)
3) Use A1 as your search field.
4) In A2, enter the following formula:
=VLOOKUP($A$1,$A$2:$C$6,3,)
Describing above parameters, in the formula:
$A$1 -> the search field (name your looking for).
$A$2:$C$6 -> The table/grid you wish to search and return values from. The left most column (A) must contain the values to be searched.
3 -> is the column number (A=1,B=2,C=3, etc) within the table/grid to return.
If you cannot make the name column your first (A) column, there are more complex ways to do this. For instance, create a new sheet which redisplays the info in the structure easier for this method, and perform the VLOOKUP on that data. Other options might exist in creating a complex formula that would get you what you want.
Also, if you can sort column A (names) it would find results faster, if your data set is large.
Excel formula
Assuming that all of your data is in a single row number 4 and between columns N and PF
Try:
{=OFFSET(N4,0,MATCH(TODAY(),N4:PF4,0)+1,1,1)}
The MATCH function looks up the value of today() in the range N4 to PF4 and returns the number of columns offset from the beginning of the range. (The 0 here does an exact match)
The OFFSET function returns a value from a cell a specified number of columns from a reference cell, in this case N4, which is the first column that contains the search data. We need to add on to this value to skip the Interest column.
Regards,
Daryl
3answers
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
