Question about Samsung SyncMaster 153V 15" Flat Panel LCD Monitor
Samsung 153V LCD Monitor Power Supply Repair Tips Troubleshooting Samsung 153V LCD power supply is just like troubleshooting those CRT type. This monitor came in with no power symptom. If you are first time repairing this type of power supply, I recommend you to first remove the switch mode power transformer. Then test every single component in the primary section, before you continue to check the secondary section. You have to be good in testing basic electronic components in order to detect the fault. You can always browse through my website just in case you do not know how to test basic electronic components. If you do not know the right way to check, you might miss out a bad component and this will lead you not able to solve the problem. After carefully checking all the components in the power supply section, I found the filter capacitor do not have any reading using digital capacitance meter (open) , the two round type fuse also open circuit, 1N4744 15 Volt zener diode short circuit and lastly the power IC TOP247F blown!. Testing the SMPS (switch mode power supply) primary winding with a **** smith fly-back tester, shows green bar which indicates good winding. What we left here were the secondary diode and filter capacitor. Upon checking them with analog meter and ESR meter, found all of them to be good condition. Other area like main board and inverter board also looks okay (Power failure rarely affect these two circuit). Now we have confirmed that only five components found to be faulty. One by one the components were replaced (except one fuse) and just before you switch on the power supply, make sure you connect a 100 watt light bulb across the live ac line. Once it is done you can then proceed to switch on the LCD monitor to look at the brightness of the bulb. If it very bright, this suggests that there are still short circuit somewhere in the power section. If it dim or totally goes off, you can now place your red probe to the secondary side to check if any dc present at their respective line. If there are DC voltages present at the output, you can switch off the power, discharge the filter capacitor (for safety purposes), remove the light bulb and connect back the new fuse to its original location. You are now hundred percent sure that the LCD power supply won
Posted on Jan 17, 2011
We replaced the power suply and back light pcb assy from another monitor whose LCD screen was faulty...
Posted on Mar 29, 2009
Jul 29, 2014 | Samsung SyncMaster 153V 15" Flat Panel LCD...
Apr 20, 2011 | Samsung SyncMaster 510N 15" LCD Monitor
Oct 27, 2010 | Samsung SyncMaster 153V 15" Flat Panel LCD...
Mar 11, 2010 | Samsung SyncMaster 153V 15" Flat Panel LCD...
Aug 31, 2009 | ViewSonic VA2226w 22" Widescreen LCD...
Aug 31, 2009 | Samsung 226BW Monitor
Aug 13, 2009 | Samsung NC10-14GW Notebook
Jul 09, 2009 | HP Computers & Internet
Jan 17, 2009 | Samsung SyncMaster 153V 15" Flat Panel LCD...
Aug 04, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Mar 27, 2013 | Samsung SyncMaster 153V 15" Flat Panel LCD...
702 people viewed this question
