Question about Boating
What is the gas/oil mix for an 80 hp johnson outboard motor
Posted by ginger vaadi on
Lee LaFarlett
    New Friend:
    Problem Solver:
  • 6 Answers
Even thought there are many expert tech's with sometimes more years of experience on this site than some you may find working in a repair shop, and of course many that simply give you their guess as the correct answer. I would recommend calling a Johnson Outboard Dealer or an outboard repair shop.
Posted on Jun 25, 2013
3 Related Answers
gerd butler
  • 20 Answers
SOURCE: I have a 1969 Johnson 33 hp outboard motor, it has
replace the plugs ,points and condenser and water pump imppellor first then start it up with the correct mix of two stroke oil and fuel mix in a barrel of water and make sure it runs before attempting the put it on a boat and go out
Posted on Jul 26, 2011
Testimonial: "Thank you so much I am really thankful for a site like this"
philwalker78
Phil Walker
  • 608 Answers
SOURCE: what type and weight of oil for johnson 28 horse outboard boat moter
Hi, mix the gas and oil at 50 to 1 and use two cycle outboard oil. Regards Phil.
Posted on Jun 30, 2012
goldbill
william moore
  • 184 Answers
SOURCE: Johnson 235HP Outboard - oil leaking from bottom leg - dark black so picking it is the two stroke oil
most 2 stroke motors will not burn all the oil in the mix and that unburned oil coats the exhaust leg and leaks out the thru hub exhaust and parting line of the lower to the housing. so keep some windex handy and clean it up.
Posted on Oct 11, 2012
Testimonial: "Thanks for your help William. I am new to two stroke outboards so your advice answered a few of my concerns - I have now got my hands on the manual for this motor and are digesting alot more information - they are complicated! Thank you"
Gas oil mix for 1990 evinrude 6hp
Mix 8 ounces of two cycle oil to one gallon of gas.
Jun 09, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Evinrude outboards
Johnson and Evinrude carbureted 2-stroke outboards since 1964 require a 50:1 fuel to oil mixture (2%) on engines without an automatic oiling system - 6 gallons of gas to 1 pint of outboard oil.
Aug 30, 2014 | Garden
Evinrude year serial number 3014-10340
3014 is a three horse 1955 Evinrude Lightwin. 16/1 fuel oil mix, points set at 0.020 and the NGK B6S plugs set at 0.030". 80-90W marine grade gear oil is used in the gearcase. Nice motors!
Aug 20, 2014 | Sierra International 18-5199 Marine...
Oct 09, 2012 | Clymer EvinrudeJohnson Outboard Shop...
What type and weight of oil for johnson 28 horse outboard boat moter
Jun 29, 2012 | Seloc Johnson Outboards 2002-2007 Repair...
What octane is best for older outbourd motors
Never had a problem using the lowest octane gas in any outboard motor. Even the old two stroke where gas and oil are mixed, the lowest octane worked fine.
Apr 24, 2012 | Boating
1985 40 hp Johnson outboard wouldnt open up and
sounds like your mix is off and it's fowling the plugs. probably too rich. make sure the level in your carb bowls isn't too high. Really sounds like you should clean and bench set your carbs. Especially if a plug change helps but doesn't last, then it's got to be your fuel mix, or maybe timing.
Jul 16, 2009 | Sport & Outdoor - Others
Hi. Just a quick one: I just bought a 1996 Johnson J35QLED. Do I have to mix oil & gas?
Is there a place under the cowling to put outboard motor oil if not mix 50 to 1 to be safe if will not hurt the motor to add oil to the gas,but if you dont you will burn up the motor. Jim OMC REtired Mech
Jul 03, 2009 | Boating
Boating Logo
357 people viewed this question
Top Boating Experts
ray gallant
Andrew Taylor
Andrew Taylor
Bill Boyd
Are you a Boating Expert? Answer questions, earn points and help others
