Question about Logitech Cordless Desktop MX 5500 Revolution
Logitech MX Revolution Left Click Button Broken
My left click button is broken, yet all the other ones work. I don't know whats going on.
Posted by bball3904 on
  • Anonymous Mar 25, 2009
    The left button behaves erratically, double clicks instead of click - it has become a nightmare to use it Logitech MX Revolution mouse
Anonymous
    New Friend:
Try using the lowest (slowest) speed in the control panel/mouse settings. It worked for me.
Posted on Jan 09, 2011
Anonymous
I have a Logitech Revolution MX 5500 Bluetooth mouse (part of the Logitech MX 550 desktop set.)
In my case, uninstalling SetPoint and re-installing solved this exact problem.
Posted on Jul 10, 2009
On touch pad, the left and right click below the pad, for the mouse, the left button doesn't click anymore?
Since the left button is a primary button it gets used quite a lot thus the button fails at some point in time.
Either the button has broken or the spring mechanism has broken.
Don't worry it can be repaired, claim warranty support if you can. The laptop needs to be partially disassembled and the buttons inspected. The button may need replacing.
Take care!
damnor01
Jun 09, 2011 | HP G70-460US Notebook
I'm sorry.I have defined my problem not precisly.My problem consists in where can I download from a User's Manual for Logitech MX 5500 Revolution keyboard & mouse,in English language.
You can download and print the instruction manual in PDF format from Logitech MX 5500 support website by clicking this link.
On the page which opens, click on "MX5500_amr.pdf (12.24 MB)" link to download the manual.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
To magnify the text of the manual, click the "+" button in Adobe Reader window as shown in the attached image.
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Oct 26, 2010 | Logitech Cordless Desktop MX 5500...
Dear Sir or Madam, About every 3rd to 5th left click of the mouse, it will double click all on its own. Can I fix it and how? This is the 2nd MX 600 mouse I have purchased for my home computer. The...
couple of solutions for a desined faulty mouse
change the mouse to a different make or change your hand.
of course you can always change the left to right button operations by going to the control panel , mouse and changing the button configuration operations
May 23, 2017 | Logitech MX 600 (ETKMOU-931595-1403) Mouse
HI vx revolution mouse repair
no sorry, once the little pins and rollers inside have broken their isn't any way. I'm really sorry.
Dec 25, 2009 | Logitech VX Revolution 931690-0403 Mouse
No left click
Go through your firewall program and allow your logitech to be allow,
Dec 17, 2009 | Logitech MX 5500 Revolution Keyboard
My VX revolution is missing too much left clicks. Sometimes I need to click 5 times to get 1 click. All the others buttons are working fine. How I can fix this? thks
Seems that the left mouse button needs to be replaced. If you have an old mouse, you can use it as a source of a spare mouse button, & replace the defective button on your VX Revolution.
However, you need to make sure that:
1. The replacement button is identical to the defective one.
2. You have enough skills to solder/desolder electronic components.
Oct 25, 2009 | Logitech Cordless Click! Mouse
Spare part for Logitech MX 5500
no spare parts from logitech. you may have to try craigslist or ebay. logitech may take as a warranty replacement but you will have to send back the keyboard and so get a spare keyboard and mouse if that is the route you plan to go.
Jul 19, 2009 | Logitech Cordless Desktop MX 5500...
Right button doesn't work; single click with left button
You can probably repair this yourself if you are technically inclined and careful.
There is a tutorial here showing how to disassemble the mouse: http://www.vk2k.com/Logitech-MX1000-Battery/
The microswitches for the buttons can be opened if you are very careful, and then you'll have to clean the contacts. Regular rubbing alcohol should work fine. Be careful not to lose any parts when opening the switch.
If the switch contacts have corroded, you may have to replace the contacts or the entire switch. You may be able to take a similar switch from another mouse (many manufacturers use similar switches). SWometimes there are MX1000 or similar logitech nonfunctioning mice being sold on eBay for parts.
Good luck
Mar 03, 2009 | Logitech MX1000 Laser Cordless...
MX Revolution left click problem
Try a bit of compressed air - perhaps dirt is jammed under the button.
If its under warranty you might want to return it to where you bought it.
Feb 27, 2008 | Logitech MX Revolution 931689 Mouse
Logitech Cordless Desktop MX 5500 Revolution Logo
2,346 people viewed this question
Top Logitech Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Lee Hodgson
Lee Hodgson
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
