I have refilled my black ink cartridge but it is still showing empty, how do I reset the printer cartridge
Unfortunately you can't....
The ink
level indicator cannot be manually re-set in the newer HP, Lexmark or Dell integrated ink cartridges, thus making
it not usable. The OEMs all leverage 'fusible links' in the nozzle plate (internal to base of ink
cartridge) which physically blows the resistors as the original ink is consumed...thus
resetting the ink cartridge's ink level monitoring capability is simply not
possible. The ink tracking feature is only available with a brand new ink
cartridge.
However, losing this feature is not necessarily
significant, because the ink level indicator usually has 20%-30% ink remaining
when it shows "low on ink".
Therefore, the warning has limited value, because customers who
prematurely replace their cartridges when they see the "low ink"
message are wasting a lot of residual ink.
Refer to any of the following videos which cover this 'low ink' subject in detail:
http://inkjet411.com/?page_id=396
(HP 60/61 Low Ink)
http://inkjet411.com/?page_id=517
(HP 74/75 Low Ink)
http://inkjet411.com/?page_id=598
(HP 901 Low Ink)
http://inkjet411.com/?page_id=1261
(HP 92-99 Nuisance Messages)
For information
on North American ink refill services at a major retailer near you (should you
wish to save ~50% on ink costs), general printing problem resolutions or advanced
HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error
bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
SOURCE: Reset ink level on CANON MP 140 PIXMA PRINTER
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
SOURCE: Lexmark x5470 all in one printer-low ink level
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
921
SOURCE: ink cartridge reset.
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
-Mustafa
SOURCE: How to reset ink level warning when refilling?
EASY!!!!: push the cancel button by 6 seconds, this deactivate the ink level sensor.
SOURCE: My refilled ink cartridge still displays empty and will not print
The ink cartridge is most likely chipped & you would not be able to reset the ink level. Purchase an original or a good compatible cartridge. Refiling newer cartridges is not a good idea.
