Question about Philips Powertouch Pt715 Mains-Operated Electric Shaver
Why has my razor got a three pin plug when only two are in bathrooms
Posted by brian cross on
Jose Diaz
  • 2,878 Answers
Europe uses 3.
Posted on Jun 11, 2013
Which way to plug new relay
Are you sure the relay isn't monkey proof? They usually plug in one way only. Three pins face the same direction, one pin is mounted obverse. Otherwise, the power pin (battery side) is larger than the other three. Check the socket where it plugs in, one slot will be larger to accept the larger pin.
Mar 06, 2015 | Cars & Trucks
Does pin placement in 4 pin plug 3 wire stator matter for a 05 HD softail deluxe?
You should have a three pin plug for a three wire stator. What in fact do you have??? AND no, the pin placement does not matter in a three wire AC alternator system but the wires come assembled to pins in a plug so I do not know how you would have them changed anyway OR have four wires.
Apr 30, 2014 | 2005 Harley Davidson FXSTI Softail...
I have ipaq x11 15454 i need to buy adapter for charging it
http://www.ebay.co.uk/sch/i.html?_trksid=p2050601.m570.l1313&_nkw=ipaq+x11+15454+&_sacat=0&_from=R40
with a UK adaptor click this link
http://www.ebay.co.uk/itm/2-Pin-to-3-Pin-Electric-Shaver-Plug-Adaptor-For-Bathroom-White-Adaptor-/221363239830?pt=UK_TravelTickets_Accessories_RL&hash=item338a46fb96
Mar 11, 2014 | HP Computers & Internet
What are some of the styles to choose from in terms of bathroom vanities?
There are three main styles of bathroom vanities - shelf vanities, wall-mounted vanities and cabinet style vanities.
Sep 03, 2012 | Belle Foret Furniture
I forget my pin
on so careles you are .you should apply for a pin again then renevw your pin .in this case you should have a valid email .so that you can recieve your new pin .
bathroom light
May 08, 2012 | Home
I have a jabra ote3 bluetooth. i don't have the manual. can i connect the bluetooth to a verizon motorola razor?
Yes,You can connect the Jabra head set to motorola razor.
Please follow the steps to connect it to motorola razor
1. Turn headset off. Press and hold until solid light comes on.
2. Activate Bluetooth on your phone.
3. Search for Bluetooth devices and select Jabra BT2070.
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 .
Thank You
Aug 11, 2010 | Cell Phones
Electric razor won't charge
I've had two different charging issues with my wet-dry electrics over the years. The first is the same one as here: The battery croaks and you need to replace it. I take the old one apart, save the screen and its housing and put the battery in the recycle bin. Then, I go on-line and simply order a new one. Unless you have a really expensive razor, replacement parts and shipping costs aren't worth the trouble.
The second is that because I use mine in the shower, the contact pins & sockets on the charger & razor develop a layer of lime or calcium scale overtime. This thin layer of scale insulates the contacts from each other and prevents the razor from charging. At first I tried high-end "Cramolin DeOxit" but with no success. Then I poured a small amount CLR on the pins and sockets and scrubbed them with an old toothbrush. After rinsing with some clean water and drying with a paper towel and a few blasts of air, it charged perfectly! So, check your charge status light first to be sure you have a good pin/socket connection before leaping for a new battery.
Dec 07, 2009 | Panasonic ES7058
I have a bathroom cabinet door that came off and now I can't get the screws to stay in as the inside of the cabinet is so damaged and wood filler does not work , even glue will not hold this door back on...
Buy a dowel pin the size of the hole in the cabnet then use carpenters glue to glue the dowel pin in place where the old hole was make sure it is a good tight fit. Next saw off the dowel pin and let set over night then drill a strating hole in the dowel pin and reinstall the door works like a chanp. Hope this helps.
Sep 28, 2009 | Duravit 6130 Starck 1.2.3 Vanity Unit w/ 2...
7526 twist cord and razor speeds up
Based on the limited info provided, it appears you have a rechargeable razor that you plug in to recharge.
I had this occur with an older shaver I had years ago. The suspected issue is tha the battery isn't fully charged and the razor is running on battery power while the cord is plugged into it and the power outlet.
However, the cord is making a loose connection at the razor or has a broken conductor in the cord. So and what is happening is that you arfe getting an intermittent power connection that allows the power to run the razor, which would be why it seems to "speed up" as any rechargeable product always run faster/better when connected directly to an electric power source.
You can look at the plug on the razor to see if the pins/connector is loose, and also carefully check the cord to see if shows signs of having been sharply kinked or bent at the razor plug end or at the power plug end or along it somewhere.
It could be as simple as replacing the power cord. Or you may have to take the razor apart to repair the charging socket at the razor to resolve this issue.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Health & Beauty
Philips Powertouch Pt715 Mains-Operated Electric Shaver Logo
51 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Robin
Robert McClure
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
