SOURCE: In reference to the Eiki LC X999 projector
I figured it out by opening the bottom. The lamp was easy to change.
SOURCE: can't find a reseasonable price for eiki
That is a Sanyo type lamp. Try searching ebay, there are several dealers that sell through there and ebay will search in price order for you.
Hope that helps
SOURCE: How can you view the
The manual for your projector is found here: Turn projector on, press MENU button and ON-SCREEN MENU will appear. Press POINT LEFT/RIGHT button(s) to move a red frame pointer to SETTING Menu icon (refer to page 37). Press POINT DOWN button to move a red frame pointer to "Lamp counter reset" and then press SELECT button.
http://www.eiki.com/resources/resourcedownload.ashx?filename=/ownersmanuals/om_x986.pdf
My assumption since it is not specifically stated on the location of the counter is it should be located close to the option to reset the counter. I would start here and look around above and below this option.
According to pg 39 the steps to reset the counter are the following:
Message "Lamp replace counter reset?" is displayed. Move pointer to [Yes] and then press SELECT button.
SOURCE: how to check lamp hours on eiki lc - x50m
It does have a lamp timer but it is only accessible at start up if you hold down several buttons when you power the projector on. Eiki only supplies the info to dealers. I will see if I can post it later from my service notes.
