Question about Symphonic ST419E TV
Is my Hitachi TV 32LD8600 equipped for DVB-C - Symphonic ST419E TV
Posted by Sylvia Jakob on
Does the tv model sylvania tvk191 have a qam tuner?
If the TV is sold in the UK, then yes it has a QAM tuner.
All TVs have to be able to pick up Freeview to legally be sold as a TV in the UK. Freeview is the public name for the DVB-T service which is our Digital Video Broadcast - Terrestrial service. DVB-T is just the standard definition channels. DVB-T2 is the version of Freeview that includes HD as well as SD channels. The QAMs are the way in which the signal is encoded. But it's really a level of detail that you don't need to go to. It's sufficient to know that the tuner is ether DVB-T for SD only, or DVB-T2 to pick up SD and HD.
Sep 08, 2014 | Televison & Video
My hitachi 32ld8600 keep turning off after 4 minutes
This is a good indication that the capacitors on the power supply are failing. Is it under warranty? If so, contact Hitachi to find a certified service center. If it isn't, you will have to find somewhere to take it to get the power supply replaced or fixed.
Apr 18, 2014 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Hitachi 32ld8600 keeps blowing fuses
There should be a short circuit at the main power supply regulator board. Check all the rectifier diodes and other components. Check the switching device for short. To get more details, http://electronicshelponline.blogspot.com/
Nov 14, 2013 | Televison & Video
Dvb lcd tv
antenna is point in the correct direction?
Oct 27, 2013 | Sony BRAVIA Televison & Video
Is my tv digital.Model JVC AV-32T4SK
Sorry your TV is NOT compatibile with DVB-C,DVB-S, DVB-T, or with any other digital technology.
have a nice day
May 10, 2011 | JVC Televison & Video
Does a samsung dv3 tv have freeview
Yes, it does.
DV3 is actually DVB meaning Digital Video Broadcasting. The stylised design of the DVB symbol makes it look more like DV3. If the TV has the DVB symbol, then it has a digital tuner and can receive digital channels, i.e. Freeview.
If you need assistance with tuning the Freeview channels or have further questions, please let me know the model number of the TV. This can be found on a label on the back of the TV.
Regards,
BElectric
Apr 24, 2011 | Televison & Video
Hitachi TV - no signal on DTV since switchover
Hi It sounds like you need to re-tune your DVB-Tuner on your TV, NOT the old analogue one, it'll be in settings or setup, or installation and use the "First Time Install" option, because it clears all old channels and loads all fresh new ones! hope this helps!
Dec 06, 2009 | Televison & Video
I have a 53" projection
No unless it has a DVB symbol on the front of the TV. HD means High Definition not Digital
Aug 21, 2009 | Hitachi Televison & Video
Symphonic ST419E TV Logo
43 people viewed this question
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
