Another word for a gun case - Computers & Internet
Posted by Thomas on
ScottieRobel
    New Friend:
    Problem Solver:
  • 10 Answers
Another word for a gun case is Holster. A holster is the best place to save your Gun from an external action. There are so many sites are available who provide the Holster at an affordable cost. They also have a huge collection of 1911 leather holster in a different shape and size. If you want to buy check the link as mentioned above.
Posted on Apr 16, 2018
Jose Diaz
  • 2,878 Answers
Holster
Posted on Jun 11, 2013
Which concealed carry holsters is good for short gun?
It depends on your desired carry style and position. Do you want to carry inside the waistband? Inside the pocket? Maybe in the ankle? What about women's concealed carry holsters? There are also brands to consider. Either way, browsing a company's "holsters by carry position" is a good place to start:
https://www.cheaperthandirt.com/category/parts-and-accessories/holsters/holsters-by-carry-positions.do
Mar 14, 2018 | Firearms
How do I search for a gun using the serial number
Follow these five steps:
    • 1 Locate the serial number for the gun you want to check. If you are purchasing a gun or checking one that is already in your possession, you can check the documentation that came with the gun. In many cases, the serial number will be noted in the owner's manual. If you don't have the owner's manual you will need to locate the serial number on the body of the gun. The serial number is usually located on the handle or inside the gun, but this does vary from manufacturer to manufacturer.
    • 2 Contact a reputable gun dealer in your area and ask them to run a serial number search for you if you're looking to buy a gun from a private party. In most cases, the dealer will charge you a small fee for this service. However, this is often the fastest, simplest method. Many gun dealers will be able to give you basic records about where and when the gun was registered.
    • 3 Check your local department of law enforcement's website to see if you can run an online gun serial number search. Some states do not maintain a database that individuals can access, so this method may not work in all areas. If you can't find the database, contact a law enforcement representative and ask if an online gun serial number search can be performed in your state.
    • 4 Contact your local police department or sheriff's office to run a gun serial number search if you are looking to purchase a pre-owned gun from a dealer. Police records will indicate whether the gun has been used in a crime or has been reported lost or stolen. Checking the serial number with the police department or sheriff's office is beneficial if you're considering buying a gun from a dealer because they can quickly check whether a gun was used for a crime or reported stolen in all states using the national ATF database.
    • 5 Check the Gun Verify database if you are purchasing a pre-owned firearm from a dealer or individual to make sure that it is not stolen. Gun Verify is a user-based database, meaning gun owners input their own information if their gun is lost or stolen.
Mar 05, 2015 | Marlin Model 60 .22 Long Rifle 19 Inch...
My glue gun doesn't heat up the glue stick.
Is the light on? The problem may be electrical, you can try plugging it into a different outlet. Try one that you are sure is working (ie unplug something that is already working and try the glue gun there). If it is getting power, there must be a problem with the interior heating coil, in which case you will have to unscrew the casing and replace some parts
Feb 15, 2013 | Crafts & Hobbies
Broken brass part in gun on power washer
most cases you need to get a new gun assembly
Mar 01, 2012 | Garden
Gun will not heat but the battery seems to be working because the light on the glue gun is on
something is probably wrong with the heating element. you can try to fix it yourself by unscrewing the plastic casing, or take it to a repair shop, or buy a new gun
Mar 06, 2011 | Crafts & Hobbies
Its a Brand new gun and when I **** it the trigger will not set so the gun will not fire
the fault is the triger return spring,,,,,,,get it looked at,,,,,
by a gun smith,,,faulty triger are dangerous,,and killers too?
Aug 27, 2010 | Beeman 1024 Takedown Rifle, Scope, Rings &...
Trouble with the 2 work lights
You need to open the gun case and check the connections to the bulb sockets inside. I have several of these guns and the only problem has been the occasional need to re-tighten the tip screws to break through the oxidized copper adjacent the screws. Good luck!
Jul 07, 2010 | Weller D550PK Professional Soldering Gun...
Gun keeps jamming. when shooting it jams.
Well you didn't give a lot of information about your gun. If you reload bullets you probably need to trim the cases. You also need to probably clean the bolt and oil the shell casing latches and make sure there isn't any dirt, powder residue or other foreign objects stuck inside the latches that keep it from gripping the bottom of the shell casing.
Nov 16, 2009 | Sport & Outdoor - Others
General interest
Purchased the Northern Industrial Dual Temperature Heat Gun Kit - Model# RP2049K Instead
Price
$27.99
332049_med.jpg 332049 FREE SHIPPING — Northern Industrial Dual Temperature Heat Gun Kit - Model# RP2049K
Dec 16, 2008 | Pro Line 10 Pc. Proline Heat Gun Kit In...
Nail Guns costs
A good-quality starter set, including both a compressor and a small nail gun, can be bought for around 200 US dollars (USD). More sophisticated models can reach 1000 USD or more. Optional features such as a hard-shell case, safety trigger, and depth adjustment can drive the price even higher. For one-time jobs, a nail gun can also be rented at hardware stores and home repair centers.
Aug 27, 2008 | Arrow ET200 Electric Brad Nail Gun
Computers & Internet Logo
159 people viewed this question
Ekse
Marvin
Marvin
