Brand new remote fresh new batteries won't turn on???
See the photo attached. use digital camer or cell. the LED from remote control must be TURN ON. otherwise open the r. control clean the keypads from corrosion, etc, resoldert any colder joint, clean the contacts batteries and replace by new ones. Try it again.
God bless you
Check the remote control for its infra-red emission. Even new pieces might have the fault. You can check its infra-red emission, by a mobile phone having camera option. If you wish to get more details about how to check a remote control, check this link.http://electronicshelponline.blogspot.com/ If the remote control emits infra-red emission, and still TV do not respond to it, the fault will be due to a damaged infrared sensor inside TV. This part can be located just behind the infrared window at the front panel of the TV set. You have to open the TV, to access it and to replace with a new one. The part will look somewhat like these.
SOURCE: i have a brand new
You may need to recode the remote since you changed batteries, and the newly installed batteries are new, and installed correctly.
SOURCE: sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
SOURCE: TV remote RM-ED002 for main TV works fine except volume
I had the same problem with sony remot control RM-ED002, take remot control apart and clean inside with damp cloth and dry with kitchen towel, thats it now use it! ;-)
When i opened mine it was some kind of moisture under volume and channel buttons, cleaning and drying it helped.
SOURCE: my remote for the harmony 550 says welcome to
First I would check to see if any of your buttons are sticking. I have found that this is a common problem with the 550 remote. I really like this remote but if nothing works check your buttons to see if any are pressed under the plastic. This remote can only work one button at a time so if one is being pressed it will not work.
SOURCE: how can i open my sony rm-ed009 remote control
insert wide flat blade (such as a wide flat bladed screw driver) into seam along one side. Twist carefully until seam starts to prise apart - carry on until you hear the "crack" of the press-tabs coming apart and repeat along the the length of the seam until you can carefully pull it apart.
