My Videoseven Monitor is just displaying a white screen (or sometimes grey) It does not respond to the computer. Â I know its not the wires or computer as I have changed the monitor to another one and the...
Hi this is the way how to
examine what's wrong with your LCD monitors. After you turned it on, you have to check that if you can see the image on the
screen or not by shining a flashlight into the screen, not directly but find
the best angle to the screen and take a look very closely. If you can see the
icons or any image, there will be a minor problem. This is because of the lamps
inside screen. Some of them were broken and it is very easy to replace. If you
cannot see anything on the screen, there'll be some problems with inverter
board. If you have soldering tool
and want to fix it by yourself, check the caps first. It may cause this
problem. Some caps might show leaking or burning spot on the board because of too
high temp. If you don't have soldering tool, you better go get a technician to
do so.
Hope this help!! If anything I
can help you with, feel free to let me know.
Thank you,
