Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Interior lights not working on Samsung Refrigeration.
All of a sudden the interior lights quit workinig in my refrigerator. Changed bulbs but that wasn't the problem.
Posted by gataylor on
Anonymous
My samsung rf265ab did the same thing after I was cleaning it and the door was open for an extended time. I noticed the the light bulbs looked good and also notice 2 tiny black buttons between the light bulbs. They were slightly extended. I pushed both in and when I opened the fridge again the lights were working. Don't know if I fixed it or just a coincidence.
Posted on Apr 26, 2009
  • Anonymous Aug 15, 2011
    I had the exact same problem after cleaning the fridge with the doors open for an extended period. When I pushed the buttons in no change - lights are still out.
Kelly
    New Friend:
I know that this is an old thread, but it may still help someone out. I tried all of the reset options and flipped the breaker. My fridge light came back on automatically when the internal temp reached 55F. I assume that it is a visual food safety feature. Now I know! This happened after cleaning the interior. Throw in into power cool mode and wait!
Posted on Dec 12, 2018
My headlights suddenly quit working on my 2007 chevy silverado
Could be just fuse blown, or headlight bulb blown, if both ok, check headlight contactor.
Dec 13, 2014 | Chevrolet Silverado Cars & Trucks
Interior lights won't come on in GE adora refrigerator
Check that the door switch buttons are working fully. If not use a little CRC or WD 40 spray on them and exercise them a few times. If that doesn't work, the electrical contacts in the switch are corroded and the switch needs to be changed. Also check each bulb in a lamp outside the refrigerator.
Jan 13, 2013 | Refrigerators
Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Our maytag refrigerator runs nonstop and doesn't get as cool, even after cleaning coils
Chek the interior lights. Make sure they are turning off. One bulb will cause these symptoms. Is the bondensor coil hot( it's the coil under the unit. If it is, The fridge is working but has a heat source that won't quit or run out.
Nov 17, 2009 | Maytag MZD2766GES Side by Side...
I have a relatively new fridge but the interior light went out. I replaced the bulb but nothing changed, is their a simple solution here?
Have someone check to see if voltage is present at the light connection, if not present, the problem is probably the door switch
Nov 10, 2009 | Refrigerators
Buzzing sound from interior light bulbs
sounds like you have an issue withthe electronic control board locates behind refrig next to the compresssor, in a white housing
Dec 30, 2008 | Amana ABB1927DE Bottom Freezer...
DAEWOO SUPER RACER 1997
Replace the benzine pedal.
May 24, 2008 | 1999 Daewoo Lanos
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
7,974 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
