2004 Chevrolet Tahoe Logo
Posted on Mar 23, 2009
Dash light fuse for 2004 chevy tahoe
Where is fuse in panel for dash light on 2004 chevy tahoe
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 04, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1630
Points
5
Where is the doom light fuse located
2answers
2002 Tahoe abs relay location
images for 2002 Tahoe abs relay location
Chevy ABS and Brake Dash Light fix - YouTube
? 24:15
https://www.youtube.com/watch?v=Jo76ylqgUR8
Dec 22, 2012 - Uploaded by Skizzot7
This is how to fix intermittent ABS and Brake dash lights on all Chevrolet ... That board is rather robust and is installed external to the vehicle in a location that sits .... I took the module out of a2002 Sierra and it is engineered with no T10 .... ABS Sensor and Harness 2000-06 Chevy Suburban Tahoe GMC ...
How I fixed a Chevy with an Abs and Brake light on - YouTube
images for 2002 tahoe wiring
2005 Chevy Tahoe
under hood or in dash panel inside check them all
2helpful
3answers
1helpful
I have a 2004 Chevy Tahoe and the dashboard and radio lights intermittently stop working. I can't seem to find a fuse for them, either.
would NOT be a fuse if they operate intermitantly. checked headlamp switch ,dash lamp reostat for proper continuity thru out is scale. may need to access a wiring diagram to assist this repair. as i recall,headlamp switch asm pulls out from dash pad.
2helpful
2answers
No dash lights in 2001 chevy tahoe. i replaced the light switch. still no dash lights
check and see if you have power to your switch, it might just be a fuse. worse case is you'll have to change the actual lights. was it starting to get dimer and dimmer?
7helpful
2answers
Power door locks on a 2004 chevy tahoe don't work
The door locks on my 1999 tahoe stopped working and I checked the fuse, which was fine. The problem turned out to be that the fuse for my cigarette lighter was bad and for some reason it also must be working in order for the door locks to work. Put in a new cigarette lighter fuse and the door locks worked again!
All brake lights went out on 2004 Chevy Tahoe
the most common cause of this is either a sticking 4 way flasher switch or the turn signal switch itself.
No power to starter 2004 chevy tahoe
Hi
It could be your neutral safety switch. It could be the starter relay which is located in the fuse panel box. It could be the smaller wire going to the starter could be loose or corroded.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
