Haved used clarfier and shock was told not enough clorine but ph and clorine are testing ok does having alot of rain have anything to do with this probem
Make the priority fixing the water with an overdose of chlorine making sure to not use the pool for swimming while doing this, after the green goes, and you will know when you have put enough chlorine in when it clears up, then re adjust your pH level. after the level is correct, use the pool as normal .
