Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
Frigidaire Gallery smoothtop range - oven does not heat up.
I have a smoothtop Frigidaire Gallery range. The oven does not heat up, but when I set the oven to heat up, it shows up on the display fine, the fan for the convection turns on, etc, but no heat comes to the heating elements. It is electric, not gas. The broiler doesn't work nor does the self clean. They seem to be working at the panel, but if you open the oven, there is no heat. The elements are cold. We checked the elements with a multi meter and they are in working order. But there is no electricity making it to these elements and there is no error. As far as the computer thinks, everything is fine, but it isn't. It has been like this for over a year. Please help! It was working one day and the very next day, it only got warm and the next time after that, there was no heat at all.
Thanks to all the great people out there with their expertise and help.
Posted by m p on
5 Related Answers
Michael Anderson
  • 172 Answers
SOURCE: get F5 error code. Burners
Hi jdaleq,
The f-5 code on the frigidaire ranges is a bad one. It is a ERC (electronic range control) failure. The repair manuals state to replace the control when the f-5 code shows up. You can also try to reset the control. To do this flip the breaker to kill the power, wait about 20 minutes then turn the power back on. If the problem returns then you will need a new ERC. The part number is.
#316418704 The price is $194.99 including shipping in the US. I do have these available to ship today. I hope this helps and please rate me when you can.
Mike
Anderson Appliance
(865)945-3808
Posted on Sep 30, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: lost manual to my electric oven, how do you clean inside of oven?
just input your model number here for a copy of the manual, located onthe inside of the oven door, or perhaps the side of the storage drawer.
Posted on Nov 23, 2008
daveyates
  • 112 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
Anonymous
  • 750 Answers
SOURCE: frigidaire electric range fef336 heating elements not heating
Range does not heat (lights and timer do not operate).
This would indicate the range is not receiving the required 220 volts. Check house hold breakers or fuses, open wiring between the terminal block and the components, and the power cord.
Please leave a rating!
Posted on Jan 31, 2009
Anonymous
  • 113 Answers
SOURCE: Fridgidaire GLEFZ384GC - 30" Electric Smoothtop Range - no heat!!
check the element if its good its probably the control board
Posted on Apr 23, 2009
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
The lower burner in the oven of my Frigidaire Gallery Gas Range will not come on. The upper burner works fine.
The ignitor often goes bad and causes them to fail to light. The igniotr is easy to replace and will fix your problem.
This tip will help you understand this more.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
Jan 27, 2010 | Frigidaire Gallery 30" Self-Cleaning...
I have a 2 year old smoothtop GE stove. I was
that clicking usually means that the erc is trying to turn on the burners,
i would unplug the range
pull it out and check all the connections of the bake element
Oct 16, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Top element wont heat wen oven is on bake
The top element normally operates only when you turn the temperature control all the up to the broil setting as it is the broiling element. If it doesn't work at the broil setting, suspect a bad brioler element or a faulty temperature control.
Aug 11, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Gallery stove, oven won't heat up (electric)
With the oven OFF, check the resistance of the bake element with a ohmmeter on the lowest scale. Rx1. If your reading is infinate, replace the element as most elements will open circuit when they burn out. They don't short out.
Jul 27, 2009 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
[email protected]
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire cooktop
Hi Bobbiflower,
Happy to help you!
Go online to www.Frigidaire .com and you can enter your model # and download the manual.
if you can not locate the answer in the book,
I think that this problem will be solved only by service!
A & E factory service is good and nation wide!
1-800-905-9505
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Jul 17, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire Electric Smoothtop Range......getting F 1 error on digital display
F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jul 15, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
726 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
