Question about Samsung Cameras
Sidekick battery not charging
My sidekick 4g is not charging. I would have to hold or turn the phone a certain way for it to charge. Its not the charger its my phone. My mom would use it and it would simply charge. I have a about 6 different chargers and only 2 are partly working for me. One wall charger and one computer USB charger to my computer. Help me.
Posted by Amanda Braham on
Cherwally
    Sergeant:
    Habit-Forming:
  • 156 Answers
That sounds to be a charger plug going bad (yes, the one from the device)
Try an electronics service to replace it for you .
Posted on Nov 19, 2017
5 Related Answers
Anonymous
SOURCE: my samsung blackjack 2 will
If the Red Led stays turned on it is as simple as this.....the solder connecting your power on button to the system board in your phone has worn off..... you must pop the power button at the top of your phone off and you will be able to see where the soldering paste has simply worn off. At my job I have a soldering machine so it was not problem for me. I simply took pasted it back to the board with tin.....now this may require some work. just pop off the top section of you phone with a flathead screw driver and pop out the power button. look closely and you should be able to see where the botton has lifted from the little greenish system board..... Find someone to solder it, put it back together and it works like new.........SEE YA
Posted on Nov 18, 2008
Anonymous
SOURCE: LG shine wont charge
yeh same problem with me, take the battery out, put it back in, then stick the charger in and it will work
Posted on Mar 05, 2009
GrinningFool
Terry Fritsch
  • 625 Answers
Zoe-
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
LG Shine Battery Charger
I hope that helps
Posted on Jul 02, 2009
Anonymous
  • 27 Answers
SOURCE: i phone non responsive wont charge or turn on
Based on your description, it sounds like this iPhone logic board isn't working properly. It could be related to the power management unit, or the battery could have simply become desoldered if you dropped the unit.
Another cause for this problem could be from water damage which may have fried the PMU chip. If this is the case and you're not experienced with BGA removal/replacing then you're best bet is probably to sell the unit AS IS for parts or repair on eBay, Craigslist, or you could sell it to me.
Hope this helps!
Posted on Jul 08, 2009
Anonymous
SOURCE: black jack 2 wont charge or turn on
take out the SIM and micro sd and turn on the phone. then shut it off again, replace sim and micro sd then turn back on. DONE! **works on samsung jack too!!!
Posted on Aug 12, 2009
My phone was charging 2 nights ago but I had to hold the charger a certain way and today my phone will not charge what do I do to fix it?
Sounds like the charging port has a bad solder joint, this can be caused by accidentally pulling the phone while it is still plugged into the charger. The charger isn't the problem and neither is the phone software the problem is the port itself has come loose from the board. It needs to be replaced.
Feb 02, 2016 | Cell Phones
Sidekick wont charge
To check if the phone is fine, connect the phone to the laptop or computer thru the USB cable. If it is charging then the phone is fine and the charger may be at fault. If not then the phone be at fault.
Oct 28, 2013 | Samsung Exhibit II 4G
Sidekick id charger light comes on but phone wont the screen wont turn on but charger light is on
Sounds like you unit is not charging. The Sidekick ID's are notorious forthat. If you have a friend that has a sidekick ID or Sidekick 3, see ifyou can try their battery to make sure you phone is working ok.
If so, your best option is to get an external charger that has a sparebattery slot That way you can charge the battery outside the phone!They run about 25-30 dollars on ebay. an extra battery is a good idea so you can have one charger at all times.
Sidekick ID and Sidekick 3 External Battery Charger
Jun 29, 2009 | T-Mobile Sidekick ID Cellular Phone
Sidekick LX won't charge
This is a COMMON problem with the Sidekick. Not just the LX but the whole line. You'd think they'd have solved it by now. Anyway, I have a WORKAROUND to bypass your problem. It won't fix ibad charger port, but it will charge your battery for only $5. Go to ebay. Type in "universal cell phone charger". Dozens of these should come up. Most are some variant of a generic China made round charger. They have clip on electrode probes which touch the contacts of your batteries and holds them to recharge them. They work not only with most cell phone batteries, but with digital cameras and pdas too. Anyway, order one that has a good instruction sheet or description. I wasted a whole day recharging one of my batteries the wrong way because the instructions didn't come with it. Generally, the more buttons, the better. These chargers are cheap and dinky looking, but THEY WORK! I charged up a Sidekick 3 battery with one. The only real issue is that they take some time to charge up . At least my SK3 battery did, simply because it's so big. I'd get another battery on ebay and TWO chargers for a total of under $12. Some of these chargers are as cheap as $3 each. I'd have one bat charging and another ready to go just to get around the longer recharge times. For $12, beats the hell out of the $35 I'd have to pay for a Sidekick 3 battery charging cradle!
Sep 11, 2008 | T-Mobile Sidekick
Phone wont charge
Stevey-
The sidekick ID charging port can go bad like the sidekick 3's. An easy workaround is to get an external cradle that has a spare battery charging slot.
The trick is that the sidekick 3 and sidekick ID batteries are the same so the sidekick ID battery can be charged by the external cradle. An extra battery is a good idea as well so you can have ine charging at all times.
Check the cradles out here.
Sidekick ID external Battery Charger
Sep 10, 2008 | T-Mobile Sidekick ID Cellular Phone
My sidekick 2 won't charge
mine stop charging sometime ago, and I switched to a nokia 3310 charger and its been working fine since. might be a little tight going in at first. good luck.
Aug 10, 2008 | T-Mobile Sidekick II
Sidekick 3 charging problems
Ok, is the sidekick 3 brand new out of the box or new to you.
The sidekick 3 has an issue with the charging port being bad.
I would contact the person who you bought it from and get a refund.
The other option is to get an external battery charger and charge the battery that way
check the link below for those
Sidekick 3 external battery charger cradle
Jun 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 wont turn on
if the light indicates but its not charging. one other thing you can do is a soft reset.take out your SIM card and batter for 30 seconds then replace the SIM card, and hold on to the R button and at the same time replace your battery, your phone should turn on and restart twice. but it will come on.
Apr 06, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick
Is it a sidekick 3? If so, is it under warranty? If yes, call t-mobile. The sidekick 3 is known to have an issue with charging ports going bad.
If not under waranty, it will run around 100 dollars to fix.
The other option is to get an external charging cradle and a spare battery. Make sure the cradel has a spare battery chargin slot. This will allow you to allows keep one battery charging and one in the phone. Both items will run about 40 dollars on ebay.
Check out the link below for some more info.
http://shop.sidekickskin.net/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Dec 12, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3
You Blew A Circut In the Charger Port Depending On the wattage of that wrong charger. Now HeresWhat you do. you Need to find out if you blew all the circuts in the phone or just the one for the charger port, Find Some One With A Sidekick Test the battery in your phone make sure its fully charged, If your Phone Comes on the rest of the circuts are fine, if it doesnt you need a new mother board. If It Does U Need To Have the Phone Repaired. Call Me 347.845.7151
PLz Be Sure To Mark The Problem Solved
Nov 26, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Cameras Logo
176 people viewed this question
Top Samsung Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Samsung Camera Expert? Answer questions, earn points and help others
