juls nunya Posted on Jun 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to program my Dish remote to venturer (AVR2000w) home theater. I cannot find a code.
  • Official Brand Answer 184 Answers
  • Posted on Jul 30, 2013
Dish
Level 0:
Answers
184
Questions
0
Helped
225159
Points
369
Hi there! My name is Kimberly and I form part of the Social Media Department with DISH. It is my pleasure to provide you the information you need today. With the Venturer on, press and hold the Aux mode button (about six seconds) on the top of the remote until all mode buttons light up, then release. Press 2, then press STAR
Press the Up arrow button once per second while pointing the remote at the Venturer. If the code for it comes up, the equipment power off.
When it does, press the POUND button. If the code entered is valid for the remote, the mode light will flash three times. To verify the code works try several different functions for that equipment.
[email protected]
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Oct 15, 2007
SOURCE: Lost Remote for my Durabrand HT-395 Home Theater Systom
There are no codes you program into the remotes unless they are learning remotes. If you did the manual search for the code, then the universal remote will not work on that unit I'm afraid. You see you are not entering the code into the remote when you push the numbers the book tells you to. What you are doing is accessing the pre programed codes that are already programed into the remote. You cannot add any codes for universal remotes unless like I said before, they are called learning type remotes. Those cost loads of cash. Good Luck
Anonymous
  • Posted on Jul 02, 2008
SOURCE: rca rt2770 home theater universal remote code
hehehe i just found it mebbe i will tell u mebbe i will jk this is it either - 0790,1913,31023,31609,31254 mebbe one of those will help. the first one worked for mine. i take it u know how to program the remote
Anonymous
  • Posted on Dec 14, 2008
SOURCE: Sony DVD Home Theater System remote control code
I have the same system and one of my dogs got to the remote. I have a philips PMDVR8/PDVR8 universal remote. I was able to get the dav-hdx265 to turn on/off and do volume up and down by using code 0200. I have not been able to get the DVD functionality to work yet, but I will post if I do.
Anonymous
  • Posted on Apr 16, 2009
SOURCE: Phillips HTS3566D Home Theater/Comcast DVR 3 Device remote
I have the same problem. The only time that I can get it to work is whenever I turn on the cable box the home theater system turns on too. When I use the DVR it will turn it on too and want to play the CD/DVD. I have a Comcast Motorola DCH3416 DVR box.
Anonymous
  • Posted on May 03, 2009
SOURCE: need to program 311w U. remote to RTD215 home theatre
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Can I program my Panasonic home theater system model #SA-HT75 to work on my dish remote so my surround sound is accessible?
Depends on the particular dish remote you have. There have been several different remotes from dish. They have a very large remote database on the dish website you probably will only get basic functions like power on/off and maybe volume up/down.
3helpful
Can't find a code to set the rca rtd315wr home theater system to dish network remote
We would be happy to help with that. Here is a list of someof the codes that we have for RCA home theater systems: 703, 852, 772, 638, 704, and 727.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codesfor your RCA home theater system provided above. Press the pound (#) button, the modelight should flash three times. Checkthat the code works by trying several different functions on the remote to makesure it will properly operate your RCA home theater system. Keep in mind that some codesmay not be compatible with your equipment. If this is the case, please try theother codes listed for that device until you find one that is compatible withyour equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
I need the code to operate a LGLHB335 Home Theater System so I can program my Dish Network remote to control it.
We would be happy to help you with getting yourDISH Network remote to control your LG LHB335. Pressand hold the AUX button located on the top of your remote until all mode buttonback lights come on, then release. Use the number buttons to enter thecode 2*836. Press the pound (#) button. To check that thecode works try several different functions on the remote to make sure it willproperly operate your theater system. Keep in mind that some codes may not be compatiblewith your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
1helpful
I am trying to find the codes for a Dish Network remote ( 6.4 IR/UHF PRO ) to program TV Emerson LC320EM1 and if possible for the Lenoxx Sound Home Theater. Thanks in advance for any help.
Hello, my name is Daniel Busa with DISH Network customer service below, are the codes for your emerson tv and a limk with instructions if the codes don't work try the powerscan method in the link I gave you.
632,516,627,654,720,532,500,526,534,536,541,573,,590,636,642,648,652
http://www.dishnetwork.com/SupportSection/setup-remote
1helpful
I have a Sony DAV-DZ120 HOme Theater system, i just got Dish Network Installed and cannot find the code for the dish network remote to run my system, just trying to use one remote for everything rather...
Sorry, your Sony remote doesn't support DishNetwork in any way. Either you will have to use 2 separate remotes or buy a programmable remote that supports all of them. One like
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6621
I need the remote control code for a venturer STS20-2 Home Theater system
hello:
u use the universele remote controller so you have to google on brand of universele remote controller site for the code otherwise you have to use remote controller from venture
2answers
Remote code
I've just been searching & found 745 Just off to see if it works!!
2helpful
3answers
Venturer universal remote code
The code I used is 0449...I have a STS20-S Venturer Home theater
 Grubhead
Grubhead
SmartAviator
SmartAviator
