Volume keys: These keys allows you to turn up or down the volume of the ringtone and the speaker. Press these keys to turn the volume display on, and to change the volume. To lower the volume of the ringer during an incoming call, press the down volume key to the desired volume, or until the option changes to Vibration All Activated. The volume keys can also be used to scroll up or down to navigate through the different menu options. These keys are also used when the Music Player is active. While on call turn on the speaker and increase the volume with the Volume Key.
The volume may be muted. In Windows, look at the volume
control (speaker) icon on the taskbar. If it is crossed-out, click on
the icon and deselect the Mute option.
• The speakers may be turned off. Press Fn-F8 to turn the speakers
on (this hot key also turns the speakers off).
• The volume level may be too low. In Windows, look at the volume
control icon on the taskbar. Fn-? Volume up Increases the sound volume.
Fn-? Volume down Decreases the sound volume.
change the function to cd or aux before you turn it off and then change the volume before going to your preferred function. It is the only way around it.
On this model it has a preset volume when it comes on. To change the preset volume press and hold the volume button on the reciever you will hear a beep or 2 and poof its done.
it just seems a setting problem.
go to AUDIO SETTINGS or MENU.it will have "ON VOLUME".
press volume control -ve to get desired volume.
press AUDIO or MENU to store volume level.Next time u turn it ON ,the volume will be what u SET. OK i hope this solves your problem.
turn your headset off. when you turn on yourheadset back on , push the volume you wish to control the volume with. this buttom you choose shound be your volume up button now.
