Question about Dell Inspiron 8500 Notebook
Administrator password I have this error message "BOOTMGR is missing" whenever I switch on my Dell Notebook and I tried to boot from a Bootable CD but I noticed it was disabled from the Dell Manufacturing Company alongside other ports that can be used for recovering a system. So I tried accessing the f12 for setup to enable the 'Boot from CD' but I was asked for an Administrator password, I tried my Window 7 password but it says 'Password Denied', now i"m stuck here and my system won't log me in... Please how can I get this Admin Password? Here is my Service Tag: 4F2N5S1 or Service Code: 9618561793 & my notebook mode is Dell Latitude E5420
Posted by Abdul-Azeez... on
Jose Diaz
  • Dell Master
  • 2,878 Answers
You may have to contact Dell directly if its a hard drive or BIOS password.
I do know using a Windows 7 install disc will repair this error (if you can get past the password). Just insert and choose repair. gl
Posted on Jun 10, 2013
5 Related Answers
Anonymous
  • 42 Answers
SOURCE: Dell XPS M1210 Administrator password and password log on problem
This is a known vista issue where it creates a backup of your profile for some reason there registry edits to try and fix it but a system restore is much easier. Follow the below steps to solve problem.
Turned computer on and immediately pressed F8 repeatedly until I got "Advanced Boot Options" select "Safe Mode" computer then opens safe mode login as admin if possible, with a "Help" window, in the help window there is an underlined "What is System Restore?" then select "Click to open System Restore" restore to a previous state before which the fault occurred.
Click OK and after config changes should be good to go.
Posted on Mar 19, 2009
NitrusInc
NitrusInc
  • 326 Answers
SOURCE: NEED ADMINISTRATOR PASSWORD FOR DELL LATITUDE C600/C500
If this password is for Windows, then you will need to contact who set the password originally. Optionally you may use tools online to reset the password. This would require purchasing a utility like SpotMau.
If this password is for the computer it self, before booting to the OS, you have to remove the BIOS battery to clear the BIOS password.
Removing the screws on the bottom of the laptop, the bezel at the top and the keyboard, check the bottom and top of the system board, you should see a flat-cell battery or a plastic coated series of batteries with a cable going to the system board.
Good luck
Posted on Apr 14, 2009
IQUIT
  • 3940 Answers
SOURCE: dell latitude d620 bios password removal
To remove a BIOS password will require the assistance of Dell Tech Support. 800-624-9896 You will have to be able to prove you are an authorized user and if out of warranty a Fee may be involved.
Posted on May 17, 2009
Anonymous
  • 34 Answers
SOURCE: Dell laptop ... inspiron 6400 System/adminstrator password
I believed this can be resolve by clean the cmos battery. you need to remove the cmos batery from the laptop then power it on then immediately turn it off. then put the battery back to the laptop then power it on keep tapping on f2 to enter setup. please follow the instructions from the link to remove the cmos battery http://tinyurl.com/yb3mhyg
Posted on Mar 29, 2010
hdwskai
Lucy Li
  • 85 Answers
SOURCE: pls i want to unkock my dell latitude d620 Administrator password
you forgot to tell us what password.
Is it a bios password or windows password?
For Windows Password, As far as I know , there are two main methods to solve the windows password problem as follows:
1st Method:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type \Administrator\ (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from \Control Panel - User Accounts\.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
Windows password Recovery software:
for example: Any Windows Password Reset 7 . It is easy and convenient to use.
http://www.windowspasswordreset.net
For Bios Password, also two methods.
1st method . Open you computer box and Discharge to the Board manually
2st method . use BIOS/CMOS Password Recovery Tool
please visit http://www.biospasswordrecovery.com/
Hope it help to you.
Posted on Jun 23, 2010
Dell bootmgr is missing
Most likely cause is that the boot order in the BIOS is set up for the HDD first. When turning on the unit, press the key needed to enter setup. Once in setup, search thru the menus for the boot order. Choose the CD drive as the first boot device, then the hard drive as second. Save and exit the setup. When rebooting, ensure the WIN XP CD is in the drive. When the screen says, "press any key to boot from CD", press a key and the WIN XO CD should take over and start the install. Once WIN XP starts installing, follow directions. On each restart after that, DO NOT press the key to boot from CD. WIN XP setup will handle everything until the reinstall is complete. After you are done, you may choose to go back to setup and change the boot order back, but it is not really necessary. The only time you will get the "press and key to boot from CD" message is when there is a bootable CD/DVD installed in the drive. Otherwise, it overlooks it and goes to the next boot device (HDD).
Sep 07, 2014 | Dell Inspiron 2600 Notebook
Reset administrative password
Reset the password to get in. Use Hiren 15.2 disk to gaet into your computer control panel and make the changes in user accounts. Change password to new one or delete completely. Reboot to get in after removing the disk
Aug 27, 2017 | Dell Latitude E5420 Notebook
Bootmgr is missing
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a
non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs
data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
hope this helps
Sep 10, 2012 | Acer TravelMate 8371 Timeline (LXTTD03077)...
Bootmgr is missing
Take one bootable windows cd rom , insert the cd rom in cd rom drive, restart your Laptop , go to bios setup and select boot from cd rom after then save and exit . your Laptop will boot from cd rom . it will take some time , when you will see action prompt , select R ( if your bootable windows cd rom is SP2 ) , select D ( if your bootable windows cd rom is SP3) . if you select R you will be prompt repair consoul , format C:\ then instal windows SP2 . if you select D , you will be prompt delite partition , delite partition C:\ after then select C to creat partition and install windows SP3. either of one windows install like that and problem will be solved. n.b. if you don,t have cd rom drive pls collect USB cd rom drive.
Jul 30, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
Dell bootmgr missing xp
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
hope this helps
Jun 17, 2012 | Dell Computers & Internet
How can i boot my Windows Seven OS if the "bootmgr is missing"? I'm installing windows seven but when windows start copying files but error message appears that required files for the...
What you need is bootable DVD/CD for installing or repairing Windows 7 to get missing 'bootmgr' or repair corrupted bootmgr...If there are files corrupt on your CD, you can get new one from shop you have purchased..Maybe just need to clean up your DVD/CD, so your DVD drives can read properly the files installation..
Aug 07, 2011 | Computers & Internet
Bootmgr missing
Causes of BOOTMGR ErrorsThere are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
Another reason you might see BOOTMGR errors is if your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from. Fixes for BOOTMGR Errors
  1. Restart the PC. The BOOTMGR error could be a fluke.
  2. Perform a startup repair of Windows. This type of installation should replace any missing or corrupt files, including BOOTMGR. Continue troubleshooting if this does not resolve the issue.
  3. Check your floppy and optical drives for media. Often times, the "BOOTMGR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your issue and it's happening regularly, you might want to consider changing the boot order in BIOS so the hard drive is listed as the first boot device.
  4. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including BOOTMGR errors.
    Note: There's usually an Auto setting in BIOS for hard disk and optical drive configurations which is usually a safe bet if you're not sure what to do.
  5. Reseat all internal data and power cables. BOOTMGR error messages could be caused by loose or malfunctioning power or controller cables.
    Try replacing the PATA or SATA cable if you suspect it might be faulty.
  6. Update your motherboard's BIOS. An outdated BIOS version can sometimes cause the "BOOTMGR is Missing" error.
  7. Perform a clean installation of Windows. This type of installation will completely remove Windows from your PC and install it again from scratch. While this will almost certainly resolve any BOOTMGR errors, it's a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows.
  8. Replace the hard drive and then perform a new installation of Windows. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
BOOTMGR Errors Apply To BOOTMGR issues apply to Windows 7 and Windows Vista operating systems only. Windows XP does not utilize BOOTMGR. The equivalent function in Windows XP is NTLDR
Whish you the best luck.
Mar 06, 2011 | HP Computers & Internet
Bootmgr is missing
You have formatted the HDD in another computer and the “boot manager” was destroyed.
There is no operating system on the HDD and therefore the error message: “BOOTMGR is missing Press Ctrl+Alt+Del to restart" appears
The second message “PXE-M0F: Existing PXE ROM” says that the notebook tries to boot form the LAN but it’s not able to find an OS using the LAN connection!
Why all this error messages appears?!
Well, I think the CD/DVD drive cannot read the inserted WinXP CD and therefore in switches to LAN.
Note; You can boot from the drive by pressing the “C” button immediately after notebook starting or you will press the F12 to get the booting menu. Then you could choose the ODD as booting source.
If you will be not able to boot from your WinXP CD I assume either the CD is faulty or the CD/DVD drive cannot handle this CD.
Jan 20, 2010 | Toshiba Satellite A135-S2356 Notebook
''BOOTMGR is missing'' I can't boot from Windows XP CD
Open cpu cabinet and Refix RAM some times bootable files not load on ram properly so this error comes.
So refix RAM memory clean dust from circuit and RAM .
Also pull cmos cell from motherbord for 5 minutes so all settings are defaults then check.
Aug 01, 2009 | Computers & Internet
Open Questions:
Dell Inspiron 8500 Notebook Logo
103 people viewed this question
Lee Hodgson
Lee Hodgson
Ekse
efs_perpends
efs_perpends
