My 40"flat screen TV goes black after ahwile the
Posted by beshram rajkumar on
    Top Expert:
  • Televison & ... Master
  • 76,416 Answers
Check its backlight inverter board, and CCFL lamps. In most cased, the back-light inverter board might need replacement. Check all the CCFL lamps too for any black edges.
Posted on Jun 10, 2013
My Panasonic plasma tv is stuck on one channel. The remote has new batteries but only works for the volume. I tried changing channels on the set itself and now the screen is black
If the screen is still on but is black, try changing the channel on the set itself back to the channel it was originally on. If you can provide me with the model name of the TV (usually somewhere on the back of the TV), I might be able to find out how to re-set up your remote with it.
Dec 13, 2016 | Panasonic Televison & Video
My sony bravia klv40ex600 won't turn on,the light indicator for power,volume and channel is on, the screen is still black
Hi, have you tried pressing the TV button that is under the On/Off button on top right hand side of remote control? Some times its possible to accidently press the DVD or VCR controls and this by-passes the TV as a remote?
Another cause can be a poor or low battery in the remote itself. If you have no luck let me know & we can try some more things, however, I have heard that The On/Off Switch on the TV can be a problem. Goodluck, Jon..
Jul 22, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My samsung LE40R74BD set works fine for about 10 mins then screen goes blank (black) . It would appear there is no back lighting. I have visually checked the psu for blown capacitors but all seem to be...
This does not seem to be a power supply issue but rather an issue with the backlight inverter board. When the screen goes black, take a flash light and focus it on the screen from a close distance and several angles. See if you notice a very faint image. Try changing the channels to make it more noticeable. Try it and let me know
May 09, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Black Screen
Now turn on tv.Have picture flicker few sec.than dies,have sound only left?Yes,than the 1 or 2 long LCD inverter boards are dead.Tries websites liike shopjimmy.com,Ebay.com to buy these refurbishes 1 or 2 long LCD inverter boards for the replacement.
Jul 17, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
Samsung tv power cycles when I get to higher channels pass 40. I attempt to change channel. Doesn't change and then front led blinks, tv screens goes blank, led flashes again and then screen is normal. I'm...
We have a similar problem when changing channels/surfing, the TV will begin to power cycle, until you unplug THE CABLE TV input, then it will turn on again and stay on as you rehook the cable and change channels....till it decides to do it again, DTV channels seem to trip it up, but not sure....if I leave it on the same channel it will run for days. Yep and the cable TV is grounded outside
Dec 19, 2009 | Samsung LN40A630 40 in. LCD TV
Black Box
You have inadvertently activated one of the closed-caption modes called T1 or Text 1. Find out how to turn the closed-captioning off and on and you'll be able to turn this off.
Mar 30, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Black screen
use your remote then turn off the text messege of your tv.the black screen that you seen is for the messege but since their is no message written in the box ,that's why you see a black box.
Jan 26, 2009 | Mitsubishi CS-40307 40" TV
Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
Mar 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
301 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
