Question about Connex 3300 240-Channels Base CB Radio
Need to know the normal use settings for the Connex 3300 HP. Changed trucks and wife cleaned the radio; I believe the settings all got messed up. Thank you very much.
Posted by cherleygrogg on
  • cherleygrogg Mar 23, 2009
    Thank you so much.
Anonymous
    Problem Solver:
  • 7 Answers
Turn the rf gain all the way uphave your pa fm am knob on am your band knob on your desired band hi rf power band hi or low depending on wich ever u want to uss
Posted on Mar 23, 2009
What watt dead key and swing on CONNEX 3300 HP
A standard 3300 hp I seen get up to 40 watts peak,
normally I would turn the audio pot up all the way never snip anything and deadkey down to 2 watts. Than adjust for forward swing, I also never run a pwr mic. Good luck
Apr 20, 2015 | Connex Radio Communications
Radio want stop scanning
your keyboard membrane is needing cleaned with IPA you must have spilled coke or pepsi or somthing conductive on its membrane so i would just look to replace it you need to perhaps replace some capacitors in the controller board section {mpu for it} i think dry caps cause this esp low value ones around the mpu
Apr 24, 2014 | Connex 3300 240-Channels Base CB Radio
How do you set regular channels and low and high on a connex 3300
Combination of hi / low switch and the band knob, I believe C band with the switch on low will give regular channels.
Jan 10, 2010 | Connex 3300 240-Channels Base CB Radio
Manual for Connex 3300 HP
The best place for anything related to cb radios and ham radios is www.cbtricks.com.
Here is a direct link to the owner's manual for a Connex 3300hp
http://www.cbtricks.com/radios/connex/cx_3300_cx_3300hp/graphics/connex_cx3300_cx3300hp_om.pdf
Dean Pitts
Rollin CBs
Aug 26, 2008 | Connex 3300 240-Channels Base CB Radio
Connex 3300 240-Channels Base CB Radio Logo
1,172 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
