Question about Lenovo 3000 N500 Notebook
Turning off the mouse pad on Lenovo 300 n500
I wish to temporarily turning off the mouse pad on Lenovo 300 n500 so it oes not get inadvertently touched while typing
Posted by lakebdm_misc on
  • Anonymous Apr 11, 2009
    i turned off the touch pad and can't open it again
  • Anonymous Mar 23, 2014
    battery pluged in not charging
    Lenovo N500
Anonymous
You have a button just to do that simle task, its un the upper right side and it has a touchpad on it, press it, looks like a display but its a button :)
One image worth 1000 words:
http://www-307.ibm.com/pc/support/site.wss/71738_touchpad.gif
Complete guide found in LENOVO support:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-71738
Posted on May 24, 2009
Anonymous
  • 3 Answers
There is a small touchpad on the laptop, just above the Pause button, which turns the main mouse pad on and off. It is situated on the far right hand side (there are also touch buttons for the volume controls there), between the N500 logo and where the power supply jack fits in.
Posted on Jul 20, 2009
odiebugs
    President:
  • 949 Answers
You can go to control panel, you should see touchpad, you should be able to open this and go under options to turn it off, you can go to devise mgr and look down until you see touchpad, and click on it and then click properties, and pick driver then disable. If you are doing this because you are going to plug in a mouse, usb, then I think you can just plug in the mouse and it will over ride the touchpad,I would try this first. I hope this works for you. Anymore questions,just post back and anyone will be more than happy to help you.
I am not sure if your lap calls it touchpad, different companys have different names,but hopfully you
get the idea,and can find it.
Posted on Mar 23, 2009
My touch pad for Lenovo N500 just stopped working; the mouse pointer is stuck. I have to use and external mouse. Please how do i have my touch pad working again
It most likely has something conductive around the edges. Clean the pad with a cloth or paper towel that has 99% isopropyl alcohol on it. Use something like a toothpick to push the cloth or paper right into the edges. Once it is clean, and completely dry, try again. If it still doesn't work you may need to check the connection inside the laptop.
~KenjiFox
Jan 07, 2011 | Lenovo 3000 N500 Notebook
The trackpad on my Lenovo n500 has somehow locked. How to get it working again?
HI there press FN key as well as F7/F8/F9 key. One of the F key mark by touch pad. Just press that by pressing FN key. Thanks.
Dec 22, 2010 | Lenovo 3000 N500 Notebook
My Lenovo mouse touch pad stack. and i didn't use it what r the posible soulutions
I do. Open the Lenovo 3000 N500 Notebook PC, and un-stick it.
You need the Service Manual.
Lenovo calls it an HMM.
Hardware Maintenance Manual
Below is the Lenovo Support link for the download page, for the Lenovo 3000 N500's Hardware Maintenance Manual. The Top file listed is the one you want.
Either the site is updating right now, or Lenovo no longer offers this manual. Clicking on the file does no good.
http://shop.lenovo.com/SEUILibrary/controller/e/web/LenovoPortal/en_US/site.workflow:SimpleSiteSearch?q=lenovo+3000+n500+hmm&cc=us&lang=en
No big deal.
Copy this link, paste it into your address bar, and press the Enter key.
It's a direct link to the HMM file.
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/45n3577_01.pdf
Regards,
joecoolvette
Nov 28, 2010 | Lenovo 3000 N500 Notebook
How do i turn off the touch pad while typing
Hi!
- you can do this thru the Mouse properties
- go to control panel, look for & click the mouse icon
- on Mouse properties, got o the TAP Tab
- near the bottom area, Under Tapping, put a check on "TAP OFF while typing"
Hopr this helps.. :D
Sep 11, 2010 | Lenovo 3000 N500 Notebook
Lenovo 300 n200 disable mouse pad
Hi. I would suggest pressing the Num Lock key and see if it goes off, press and hold Function(Fn) button and hit the Num Lock key or press and hold the shift key and press the Num Lock key. Hope This Helps
Jun 08, 2010 | Lenovo 3000 N200 Notebook
I have a Lenovo N500 and the mouse pad surface has worn through after only a years work on this machine - I have managed to polish the surface off with use - does anyone know if you can replace this as its...
Hi richardta683 , since you are using N500 you can call their 24/7 tech support at 1-800-426-7378. They will certainly help you on your concern.
Hope this helps...
Apr 09, 2010 | Lenovo 3000 N500 Notebook
Lenovo n500 laptop ... mouse pad not working
The mouse pad maybe faulty or the ribbon cable from the mouse pad to the motherboard may not be properly connected. Reseat this cable.
You can connect an USB optical mouse to the laptop. I prefer you use a USB mouse all the time over the mouse pad.
Sep 29, 2009 | Lenovo 3000 N500 Notebook
My Lenovo 3000 N500 PC notebook touch pad is dead. What should I do to open it?
I had the same problem. There is a touchpad on the laptop, just above the Pause button, which turns the pad on and off. It is situated on the far right hand side (there are also touch buttons for the volume controls there), between the N500 logo and where the power supply jack fits in.
Jun 08, 2009 | Lenovo 3000 N500 Notebook
Mouse is not responding at all
you need to go to device manager...
right click "my Computer"
select "manage"
select "device manager"
click the + sign for "mice and other pointing devices"
select your touch pad...
try to enable it or find what is wrong from there
You'll need a USB mouse or something of that ilk to do it.
good luck
Apr 10, 2009 | Lenovo 3000 N500 Notebook
Lenovo 3000 N500 Notebook Logo
7,174 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
