Question about LG RH266 Recorder
Veon 50inch with built in freeview unable to get it to work
Posted by Sheree Marino on
I just bought a 19 inch Veon TV with built in Freeview. I can get TV 1 - 4. However, for the rest of the freeview channels - the reception is very very poor. Any reasons for this?
Hi Jane,
The main terrestrial channels generally have a higher signalstrength, so you may not get much better. Try auto retuning again. Also check line of sight of your aerial - does it point at a potential obstruction? (eg:hill or trees being the most likely culprits).
How do I connect Veon 50" TV to sky decoder?
you probably just have a bad connection.
try washing the tv.
submerge it in the bath tub, reconnect.
problem solved!
Veon tv manual
The eject button on the remote appears as an upward-pointing arrow with an underline - see below image. The eject button on the TV has a similar symbol.
However, I suspect that in your case, you might not be having a Remote.
This link says that your TV doesn't come with a Remote and DVD cannot be ejected without the remote :
VEON 19 LED TV DVD FREEVIEW COMBO A1823511 1
2answers
My veon 32" has no picture but sound only
Hi my veon tv is 50inch LED turning on green then off red but no picture it had sound but not any more so no picture or sound can't find reset either and is 2 years old please help.thank you
2helpful
I have an acer aspire z5700 all in one pc with built in freeview and when i try to set up the freeview it says windows media center is unable to determine my tv signal.can you tell me how i can get a...
I am not sure what Freeview is, but Windows Media Center has a TV program built into it. Turn on Windows Media Center, go to the options section, and run the TV setup. Once you have TV working, just watch it in WMC.
If you don't want to do that, from the phrasing of your question, this should still solve the problem with freeview.
Built in freeview doesn't work but digibox does
Have you done a channel search on both tv sources(atv and dtv). most new tv's will automatically start will "New Install". If you havent had a digital installed recently then this could the problem. set top boxes and TV's will pick up the signal ok but others wont.
Samsung Digital TV and Sony DVD Recorder
hi, did you find a solution? i have in built freeview and have bought a recorder but i cant pick up any freeview channels on it. the dvd recorder is a Wharfedale DVDRHD400 cheers tom
LG RH266 Recorder Logo
Ekse
