SOURCE: Jenn-Air stove locked
I tried pulling my oven out so I could unplug it and the door just popped open and the codes stopped beeping....
SOURCE: Jenn Air Range SVD48600W (Circa 1998?)
Why are the oven indicator lights flashing?
Answer:
When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
SOURCE: JENN-AIR SCE30600 COOLING FAN & OVEN LIGHT STAYS ON
small circuit board in back for fan & LIGHT BAD.
SOURCE: Jenn Air SVE47600b dead touch panel and blower runs constantly
I have had similar problems:
Display was the Part # 71001799 circuit board..$175+labor
Oven blower problem was control relay board, part# 12001689...$224+labor
My solution. replace with non-Jenn Air.
Check Consumer Reports. Jenn Air has high repair history.
SOURCE: Does anyone know where i can get an instruction on
I just replaced the panel overlay on my stove and that did fix the problem (of the 3,6,9 buttons not working). I found the part for under $110 on line and replaced it myself.
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
