Try hitting function key F11. Firefox is probably in full screen mode. F11 will toggle it to normal mode or if you put your cursor to the top of the screen there should be a drop down bar that lets you shrink the size.
right at the top in the right hand corner there are set of tabs
one is a line , the other is 2 squares off set and the last is a red section with a white X
the line reduces the page to the task bar so that you can look at other pages , the off squares brings the page from 1/2 size to full screen and the red one closes off the page
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Launch the Web browser on your Mac system. Unless you have changed the home page, the Apple site greets you.
Click the green "+" symbol in the upper left corner of the window. This enlarges the window so it takes up the entire screen. If you want to return the window to the former size, click the green "+" again.
In most cases this problem comes up by Antivirus program. It checkes running files. To identify the problem try disale antivirus program temporary, start your game and see what happens.
that is Fire Fox. and yes, it is controlled in fire fox. Go to View, and Zoom. make sure thats all turned off or reset to normal. Then goto page style and make sure that is set to basic style, and then go to encoding and choose unicode utf8
This document explains the different results obtained when using or not using the Automatic Reduction (or Auto Reduction) Feature. The following issues usually result when the Automatic Reduction feature is not set correctly:
Faxes printing too small
Faxes printing on more than one page
A blank page ejecting between each printed fax page
This feature can be turned ON (the default) or OFF from the Advanced Fax Features menu.
The two main purposes of the Auto Reduction feature
Fits a received fax page onto the paper size loaded in the paper tray and selected in the paper size setting of the Basic Fax Setup. For example; if letter size paper is loaded in the paper tray and selected in the fax settings and a legal size document is received, each page will be reduced and printed on one letter sized paper.
Allows the addition of the fax header margin at the top of every printed fax without extending the fax onto another page. The fax header is printed at the top of every fax received with identifying information about the fax sender. Since this increases the overall page length, the page must be reduced to fit onto one page. Auto reduction slightly shrinks the fax as it is received so the entire page will print on one piece of paper even though a top margin is allowed for the fax header.
If its reduced in size during transmit or copy then simply place a letter size document in the feeder and close the two sliders up to the sides of the paper. If you don't close the slider up to the paper it will go into auto reduction
Oh, wow! Completely forgot about that. Nice one Ctau, that one deserves a FixYa!
Have you tried uninstalling then reinstalling Firefox?
