Question about Frigidaire Freezers
Mfu14f3gw2 wiring diargram
Does anyone have the wiring diagram for the Frigidaire MFU14F3GW2? Thanks, Jon
Posted by Jon Granat on
Electrolux
  • Official Brand Answer
  • 4,342 Answers
Good Morning Jon - The best way to locate a Wiring Diagram for this particular unit, MFU14F3GW2 is by visiting the manufacturer website. The Owner's Guide and Parts Manual are also available. Hope this information is helpful and if there is anything else that I can help you with, please feel free to reconnect!
Posted on Jun 18, 2013
1 Related Answer
mike fuson
  • 636 Answers
SOURCE: my freezer MFU14F3GW2 started kicking the breaker.
I would think that the motor has seized on it
Posted on Jul 25, 2009
Thank would guide me about this problem: my freezer frigidaire ffu17f5hwd tells me E8, referred this error
Good Afternoon edgar corro, thanks for your post!
Based off the information you have provided your Frigidaire freezer is displaying an error code "E8". An "E8" error code typically stands for a shorted thermistor this could be a possible miscommunication with the wiring harness, control board, or thermistor. Since it could be anyone of these underlying issues I would suggest contacting a professional technician since they have the appropriate tools to pinpoint the parts needed for repair. Best of luck! -Matt
Feb 05, 2015 | Frigidaire Freezers
Frigidaire triangle symbol
Good Morning Jon, this is Z. Thank you for allowing me to assist you!
I see that your post is listed under Frigidaire freezers. Please help me understand if the question you are asking is related to the "UP" and "DOWN" arrows that are designed to change the temperature setting? If you are speaking about another triangle symbol, I will need your model number please. The serial tag, which lists your model number, is normally located inside the cabinet, on the left side wall. With this information I can better address the issue at hand. Thank you!
Jul 25, 2014 | Frigidaire Freezers
Where can i find the repair manual for frigidaire freezer model lffu1465dw6
Good Afternoon Gene, thank you for your question! I understand you are seeking a repair manual on your Frigidaire freezer, LFFU1465DW6. I have located the Owner's Guide, Wiring Diagram and Parts Manual on the manufacturer website. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Aug 17, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Need diagram for thermostat for chest freezer
The green wire is a safety ground and will attach to the body of your freezer somewhere not far from the thermostat. It really does not matter where it attaches as long as it is a clean piece of metal. Here is a link to a wiring diagram but it is not showing the green wire. HERE
If you have questions please let me know, Thanks Sea Breeze
Mar 08, 2013 | Frigidaire 15 cu. ft. / 425 liter Chest...
Freezer wont shut off and goes to -10f regardless the thermostat setting thermostat is on the outside door(digital)
I'd say the freezer thermostat is stuck closed. You will have to verify this with a meter. The wiring diagram is on the back of most freezers. Good luck.
Jul 13, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
Sep 23, 2017 | Frigidaire Freezers
Freezer will not turn on
Sounds like the sensor circuit may be open. Here is the problem, either it has a board that's bad or the sensor is out. Ohm the sensor circuit and record the temp the box is at in refrigerator and freezer. then the ohm reading. Contact manufacturer or representative of manufacturer, and ask what the sensor should read at the temps you have.
Generally if you get a reading on the sensor circut the sensor is ok, and the board is out BUT not always. this is why you need the temperature and the ohm readings. Sometimes the wire diagram has a legend with these reading on it. Look all around the underneath and behind sections for an envelope containing the wire diagram.
Apr 16, 2009 | Freezers
Freezers Logo
81 people viewed this question
Top Frigidaire Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Marvin
Marvin
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
