G Shock watch hands don't line up with time. Gshock hands don't line up with time.
Click this link to download the manual
http://world.casio.com/wat/download/en/manual/
SOURCE: Casio G-Shock G-7400 Watch
Thought this would happen when I sent you a request to help me simply change the analog time on my watch.
Your repsone to free suppor tis asking me to enter into a arrangement that requires payment.
I've solved the problem from another site free of charge.
I'm very disillusioned with the way you promote your site and will definitley recommending to others to stay clear of it.
COmes across as we can help you free of charge but bottomline is that this won't happen.
Onlty wanted to know how I change the analog time on my watch - could go to the Jewler to do this free of charge - thought the internet would help but your company has prolonged the support immensely.
Regards,
Paul Stirling
SOURCE: need to fix time on Casio G-Shock
The hands are set independent from the digital display
Setting CASIO G-Shock Watch
1) Home City
2) Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C __ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached (high beep).
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands before correct analog time is reached. Press D to step to current time (hands only go forward). Press A to exit H-Set mode. Press C to return to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
SOURCE: how do you set the time with the hands on a CASIO
If you've lost the manual, you may find it here on the Casio site
SOURCE: adjust the time in a casio g-shock shock resist watch
You can get instructions from the Casio web site.
Go to the
casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read
the number of the back of your watch and enter it into the search box
Click
on "search" and the download your instructions.
