Question about Frigidaire FEQ1442ES Electric Dryer
IS THIS MODEL STILL AVAILABLE? OR WHICH MODEL REPLACED IT? IT NEEDS TO STACK ON EXISTING WASHER
Posted by RAY FANNIN on
Bill Boyd
    Top Expert:
  • Frigidaire Master
  • 53,816 Answers
Best talk to an appliance retailer that deals in your model to get the right details for what you want to know. make sure have the model for your machine when you go.
Posted on Jun 09, 2013
Can you stack this washer and dryer?
You can stack, will you be able to reach. Racks can be made to stack any normal washer and dryer.
Mar 14, 2016 | Whirlpool WFW9750WW Duet Steam Front Load...
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool dryer model # WED9270XW1? If yes, what stacking kit do I need to use?
You can stack just about any dryer on any washer, so long that the controls of the washer are on the the top of the washer has no penetrations and no control.In general, dryers are independent from the washer and are light weight.
So the conclusion: so long that the dryer does not interfere with operating the washer - YOU ARE A OK :-)
Oct 14, 2014 | Whirlpool 8541503 Duet Stack Kit 8541503
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool washer model # WED9270XW1? If yes, what stacking kit do I need to use? Can I stack a new whirlpool washer model # WFW72HED
As we could see new one are not compatible with older one as size and dimension of new washer are changed but in case you could try .It is simple just try compatibility of your older washer stack kit with new one in most new model
ML2000 stack model, washer is not draining or spinning in spin cycle?
Call a service repair agent. This is a problem that needs some dis-assembly to fix.
Oct 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
The washer on my double stack won't drain or spin.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Without a complete model number, I'm guessing but usually, washers have a lid lock built in that prevents the washer from draining or spinning unless the lid is closed.
If the lid lock is defective, the washer probably won't go into spin mode.
Check yours for the lock, where it attaches and replace it. It's probably not too expensive.
Oct 27, 2009 | Kenmore Washing Machines
F35 code? appears and then the washer just sits there with the f35 code blinking.....
the wather level switch needs to be replaced part number W10249845 which is not available. My duet is less than 1 yr old and I have been dealing with Advantage for 30 days to get this fixed. I am now waiting on a full refund for the washer since they cant get this part from 2 manufactuers. We now have to buy a new washer for 500 more and by the way the stack shelving that I purchased with this washer does not work with any new WP FL Washer there is another 400 plus the new warranty. Whirlpool should bite the bullet and do a recall.
Sep 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stacking Frigidaire Washer Dryers
no you do not need to put them on rollers. yes it would make it easier to service them but rollers would not be stable enough to keep the washr from shaking in spin cycle.
Jan 23, 2009 | Frigidaire Washing Machines
My Maytag Front load stack unit washer/dryer model # MLE2000AYW
I had a similar problem, My washer spun but the clothes were still soaked with water. We replaced the inertia switch. That solved it.
Dec 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
Nov 12, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire FEQ1442ES Electric Dryer Logo
52 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Dennis Boxerman
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
