Computers & Internet Logo
Anonymous Posted on Jun 09, 2013
My graphic card running so fast
Yesterday i bought this PC from someone. I went to him and check it there. It was working very well. Brought it to my house and thought to change HARDDISK. Opened PC and tried to change harddisk but the harddisk wasn't the same as i had one before. I closed the pc immediatly and turned it on... The graphic card has one fuzzer on it. It starts running fast then stops...it continues with that rhytme again and again...
Lars Olsson
Level 3:
Brigadier General:
  • HP Master 3,400 Answers
  • Posted on Jun 09, 2013
Lars Olsson
HP Master
Level 3:
Brigadier General:
Answers
3400
Questions
Helped
1048286
Points
10330
5 Related Answers
Anonymous
  • 150 Answers
  • Posted on Sep 22, 2007
SOURCE: my pc does not support windows xp sp3
What type of sound is the hard drive making? Clicking, grinding, loud whine's? Typically this is a sign that the hard drive is on it's way out, I've personally had bad expirence with seagate drives and I try to avoid there products. I would suggest backing that drive up to an external drive while you can, eventually that drive will die and need to be replaced, so back it up while you still can. I recommend Maxtor, or western digital drives, I've had great luck with those. Good Luck Hope this helps
Anonymous
  • 406 Answers
  • Posted on Feb 18, 2008
SOURCE: orange light blinking and wont start
Hi, I think if its continuous beeping sound then Take out ram And clean with dry cloth the golden surface. And on mother board clean with vaccum cleaner. and fix it again.
If the same beep sound is coming try changing the Ram.
Best Regards
Rafique
Anonymous
  • 88 Answers
  • Posted on Jan 19, 2009
SOURCE: HP d530 PC - SATA Harddisk - Chassis does not close any more
Martin,
They make SATA cables with a 90 degree connection on one end.
Hopefully this will solve your clearance problems with your case.
Here is a link to website that carries these.
Website Link
They work great and fit tight against the drive.
Hope this helps,
Eric
Anonymous
  • 272 Answers
  • Posted on May 29, 2009
SOURCE: I get keyboard failure when i put on my PC
How keyboard problem can be solved by changing harddrive ??
Try a new keyboard . If ps2 does not work, you may try an use keyboard too.
Anonymous
  • 374 Answers
  • Posted on Jul 05, 2009
SOURCE: SMPS problem?
hi there,
what about changing your power supply at cpu,disconnect the avr before doing this,disconnect all terminals leads on pc board,cd room and hardisk if you have spare of
power supply or other pc,you can installed to check before buy one,if still shut down whiile power supply was replaced,replace cmos battery,check also your video card and memory card,you can run your windows with out hardisk and cd room just to check if your system is running functionaly.regards
1helpful
Hi, I have an acer aspire 5542 laptop it was bought 4 months in Italy where my uncle bought it as a gift for me. 3 days ago when i got home from work i tried to open the laptop and the lcd is just black....
Sorry to hear about your trouble. Unfortunately, most laptops have integrated graphics cards meaning, the graphic card is built into the motherboard. So, to replace the graphics card means you have to replace the motherboard, which can be more expensive(depending on who does the replacing).
You can try and find a replacement part yourself by visiting some online computer parts stores or maybe some locally.
I recommend trying the link below, which I use all the time.
Click here
If the laptop is under warranty, and the fault is not yours, Acer should not charge you. Depending on the circumstances maybe you can escalate the repair ticket to have the cost reduced or waived entirely.
Good luck.
G33k
HI, I have a GALAXY 9800 GT 512MB , It was working fine for last 1 year, but yesterday when I was doing some word processing all of a sudden the screen went black with a message (VGA IN, VGA NO SIGNAL) ,I...
Then your GPU is faulty, if it is still covered by warranty, contact the seller you bought it from,
otherwise you can try to have it serviced or purchase a new card.
2helpful
2answers
Monitor blacks out after few seconds
Since you opened up the PC the first thing to do would be to make sure the graphics card (if it is a standalone card) is seated properly. Remove it, blow out any dust, and re-install it. If that does not fix the problem, or if the graphics are built into the PC, try getting a cheap video card (or borrow one from a friend) and that should fix the problem, since you have ruled out the monitor as the problem.
Also, it could be a problem with the power supply. I'd chase down the graphics card side first though. If that doesn't work, try the same procedure with the power supply.
Note: I have run into instances where an AGP slot got "zapped" by someone opening the case and not taking proper static precautions, so be careful, always unplug the PC and ground yourself to the case before touching anything. If you try a video card you know is functioning and it still doesn't work, pick up a PCI graphics card and see if that works.
Installed FSX & it worked fine yesterday. Tried to play it today & it says my graphics card doesn't meet minimum requirements. What gives?
Once you reboot or restart your system, FSX will run the checks that it didn't when you installed it hence the message. Upgrade your card and you will be okay. Suggest an Nvidia GTS250 if you want lighting fast graphics.
2answers
I BROUGHT A PC X200 FROM ASDA ON 31-8-09 WITH VISTA PRE. USED IT A WHILE UNTIL IVE GOT MY MAIN PC FIXED. ON REUSING PC AFTER A NUMBER OF LONG UPDATES I GOT BLUE SCREEN ERRORS. AM I RIGHT IN THINKING I CAN...
all i can suggest is that u look at http://www.vistabluescreen.com/
and you should be able to upgrade to win 7 but it depends on the terms and conditions of the sale when u purchased the pc (i also dont know if time limits apply for it aswell)
(i bought a new machine with vista on it 2 weeks ago and i am unable to get the upgrade , i knew this when i bought it cause i wanted xp on it anyway )
hope this helps in some way
2answers
Blank screen with curser
If your Acer is brand new and less than 1 year old then I suggest returning it to the shop where you bought it and have it repaired under warranty. If you try to repair it you may void your warranty.
Monitor not working
It may well be dead. Try testing the monitor on another working PC. Also try a working monitor on the problem PC. Then you will know whether it's the monitor or the PC graphics card that's faulty.
GeForce 6600 AGP 8x 256 MB in Asrock 7s41gx
get another hard disk and do a fresh install of xp then the drivers and the game see if its all ok
if it is then its your drivers get them out and replace them
with the latest from nvidia. or format and go again
hope this helps
Motherboard problem
Hiw can u say's its display problem,Have u checked the signals on k/b ?
If not check the Num lock status in keyboard. Press the Num lock key ,if the light glows and stands for sometime display is ok,but ur vga adapter is the problem.
Otherwise problem maybe with m/b or psu.
Pl check it.
Regards.
Was this soultion useful?give the apppriciation by rating it.
How to properly install Asus N6200 AGP video card
Set refresh to 60hz
Set color to highest position.
If this is an LCD, set it to the highest resolution
If this is a 15" or 17" CRT, set resolution to 1024x768.
If this is a 19" CRT, set resolution to 1280x1024.
Also, do not use the drivers on the CD. Go too nvidia.com and download the latest there.
Also, if you can get into the BIOS, try to disable the on board graphics if you see an option for it.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
