Question about Gateway GT5220 PC Desktop
Compatible Gateway Motherboard
Does anyone know of a compatible motherboard for a Gateway GT5220 Desktop PC that would use the same memory, etc. as the original motherboard?
Posted by Peggy on
MICHAEL HEMINSLEY
    New Friend:
  • 13 Answers
BIOSTAR MCP6P M2+ 6.X AM3/AM2+/AM2 NVIDIA GeForce 6150 / nForce 430 Micro ATX AMD Motherboard
Posted on Jun 09, 2013
3 Related Answers
vcmichael
V C MICHAEL
  • 115 Answers
SOURCE: hard drive compatible with gateway 300xl desktop computer
I think there is no SATA ports on its mother board. So SATA Hard disks cannot be used on this system.
Without any dobt you can use PATA (the one that we used to see everywhere) can be used. There is no question of compatibility; any size 80,or 160 GB or even more can be used.
Posted on Dec 18, 2008
Anonymous
  • 585 Answers
SOURCE: My GT5220 is less than two years old and the
If you have the original Mobo in hand and feel a little curious about how at only two years old it doesn't work anymore, consider this. Inspect the large electrolytic capacitors on the board. (those round cylindrical things that stand up) for swelling. The tops should be perfectly flat. If they show swelling (domed) they have failed, and replacing them will likely bring it back. It takes good soldering skills and at least a 60-watt (100-watt preferred for this job because of the amount of heat required) temperature-regulated soldering iron, and the replacement parts. The bonus to this is you will not need to re-install your windows system. You might even feel a little like you have beat the system.
Posted on May 15, 2009
Gateway GT5040 Graphics Card
This model Gateway desktop computer has a built-in video card.
Connect the monitor to the Gateway motherboard video port and the boot up and go into the BIOS and select disable the built-in video.
Shut down then connect the monitor to the 8800GTX video card and boot up the Gateway computer. The video should then appear in the monitor.
Feb 14, 2013 | Gateway GT5040 PC Desktop
Gateway gt5220 has cmos checksum error - defaults loaded
Open the cpu cabinet cover then pull cmos cell from motherboard for 10 minutes then all settings defaults.Then when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then set bios settings.Let me know if you need further assistance.Thanks for using FixYa
Nov 18, 2011 | Gateway GT5220 PC Desktop
What type of ram (memory) is compatible with the gateway 4000676 motherboard
The memory that can be be use is DDR1 400mghz and can be expanded to 4gb.
For more detail of the specs, go to this site................ http://support.gateway.com/s/PC/R/1008835/1008835sp3.shtml
Hope that helps!
Nov 10, 2011 | Gateway (4000676) Motherboard
Gateway mfatxstl elp 500c. MEMORY PROBLEM
Check all of the other connections all around where you was at. Sometimes it dont take much to knock one of them loose. Also take the chip backn out and take a pencil eraser and clean the contacts on the chip with it.
May 24, 2010 | Gateway GT5220 PC Desktop
I removed the old memory and installed 4 1GB cards and the computer doesn't work? Help.
Adding new memory can be tricky. First the new memory has to be compatible with the motherboard.
By that I mean, you need to know how much memory the motherboard can max out at.Can it take only 2 GB or 4GB etc. And it has to be a match to what memory speed your motherboard can handle. If your motherboard takes DDR than you must put DDR in, if it takes DDR2 than you must put DDR2 in. Look at the old memory, and try to match all the numbers you find on it. Than look up the memory specs for the motherboard to find out how much it can take.
Any computer will not operate corecctly if the memory is the wrong kind, or installed wrong.
Jul 02, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
When choosing a memory for your PC
In the manual of your motherboard you can see what memosticks suported and compatible on the motherboard
If you dont have the manual but know the name of the motherboard you can find same info on the producers site
If you want me to link you you need to tell me name on your motherboard
Good luck
Dec 08, 2008 | Asrock 775i65GV Motherboard
Should i get rid of this gateway
Before getting rid think twice. Because the value you for second selling is very low, Buying a new one is quite an asset. If the problem you had is minor i suggest to keep it otherwise (Problem with motherboard, processor) then get rid of it.
Jan 01, 2008 | Gateway GT5220 PC Desktop
Gateway GT5220 PC Desktop Logo
122 people viewed this question
Top Gateway Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
