Question about Car Audio & Video
I have a hifonics Zrx1200.2 amp. I am running 2 Rockford fosgate p3 12s with it. The specs on amp and subs match perfect. So I have everything wired correctly, it least I sureeee think so. Subs are dvc 4 ohm and I have them wired at 2 ohms each. So anyway on to the problem.. I turn on my car and the amp lights up and everything seems to work fine, I will have volume at 45 of 60 and it will sound greatttt. But then, after about 15 minutes the amp gets SO hot, I could fry eggs on it. Then if I play it for another minute or two it goes into protection mode. It was doing this when I had it on the floor of my trunk and then I realized the vents were covered so I was like o this is easy to fix and made a little mount for it so it could get air to cool it. After this I went for a drive and sure enough it was just as hot as before accept after 20 minutes this time. Any ideas? I don't want to put into protection mode all the time... I am running 4 Guage wire for power and ground and 12 Guage for sub wires. Thanks in advance!
    New Friend:
  • 12 Answers
U could just not have enough battery power or the load on the amp is to much. if the amp is in stereo mode it should work but if it is in bridge mode the ohms would be to low .. best thing is to get a sub amp with a 1 ohm stable capacity.. and you amp should be at least one third more powerful than the subs..eg: if the 2 subs is 1000 w each the the amp should be 2500 rms and up to prevent the amp from maxing out and over heating etc.
Posted on Jun 15, 2013
  • Cody Adomat Jun 16, 2013
    Thanks that was helpful! But the reason I got the stuff I did is cause I don't have much money and so anyways I have found online that class a/b amps like this one naturally run hot (wich mine was overheating so obviously not right) but I didn't have the volts (gain) on amp matching my head unit 2v pre amp output. I did that and got 2 old comply fans and it stays cooler! If I pound at 50 of 60 volume it gets hottt. But hasn't overheated yet. So I think I solved it! And I don't think it's pulling to much from the battery cause my lights don't dim super bad.. Whereas my friend is running a power acoustic mono d 2400 watt max amp and his lights dim way more. I don't know much about battery stuff in cars.
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Posted on May 29, 2008
Tim Swiercinsky
  • 1126 Answers
SOURCE: 2 12" dvc subs 2 ohm stable amp
+ on amp output to + on speaker #1 to + on speaker #2. - on amp output to - on speaker #1 to - on speaker #2. This is a parallel circuit....4 ohms in parallel with 4 ohms = 2 ohms. IF it were wired in series....would represent 8 ohm load.
Posted on Nov 12, 2009
Christopher D D
  • 3 Answers
SOURCE: my nitro bmw 486 cuts out when i turn the volume up alittle bit,subs start crackling and distorting turn volume back down sounds just fine amp doesn't go to protect mode still works 4 guage wire a
The First thing I would check is, check the voltage at the power terminals of the amp. This to make sure that there is no problems with the supply voltage. If you have a fuse in the Red 4 gauge power line, check it before and after the fuse. The last place to check is where red 4 gauge wire connets to the main power supply.
Protection mode will also activate when the amp temperature gets too high. But since it is stated that the amp is anly warm to the touch. That should not be the problem.
I would check the speakers impedance if it is too low you might get same symptoms that you are experiencinng now. Also if the impedance is too high can
also cause this problem. Measure at the speaker with the speaker wiring disconnected from the speaker. Then take measurements at amp outputs. Also disconnect the wire from the amp and take the final and compaire the measurements, they all should be very close, I would say with in 1 or 2 Ohms.
Is it possible that the amp got wet, would you be willing to open the amp up to see if any IE( rain water had gotten on the board.
Posted on Aug 28, 2012
At high levels sounds more like a thump than boom
Make sure the GAIN on the amp is not all the way up it is not a loud button. your amp should be tuned to your subs with the GAIN or on some LEVEL. if they are not matched you will clip the amp and subs and blow them.Is it in the proper sized box? is the amp able to run the sub at the ohm it needs to be run at and do you have the the ohm load correct on the sub. there is a lot to it. if your not familiar with it go to youtube and watch some videos there is some good vids there and will help you learn to wire a sub correctly i have enclosed a link easy to use.
Rockford Fosgate Woofer WiringWizard
Mar 07, 2016 | Rockford Fosgate Car Audio & Video
Does anybody know what watt this is. it's sosed to be a 2400 watt and why does it have 2 ports on each side to hook up speaker wire And what's the best way to run it with a 800 watt Rockford fosgate
dual voice coil subs hook up mono on amp, from amp - from right side + from left side of amp run to sub n then jumper wires from one side of sub to the other side goes negative jumps on positive and positive jumps on negative
Apr 03, 2015 | Rockford Fosgate Car Audio & Video
What kind of amp can adequately power P112 S8 subs
you shouldnt run it at 8 ohm it shows what ohms it can handle . to run it at 1 ohm you would need 2 subs to do this. and no i wouldnt run an 8 ohm sub on the amp.
Aug 23, 2012 | Rockford Fosgate Punch Stage P112 S8 Car...
Im looking at this rockford fosgate p700-1bd amp brand new for $300 it comes with a birth sheet it says 750 rms on a 1ohm load. i cant find any reviews about it 225 rms x 1 @ 4-Ohms 450 rms x 1 @ 2-Ohms...
You can't go wrong with Rockford, in my opinion. Everything they make is well built and high quality. I personally have two Rockford p500-1bd amps hooked up to four 12 inch subs in my car and those amps make those subs slam. I have them wired down to 1 ohm and the specs say that they should be pushing 500 rms a piece at 1 ohm so that p700-1bd amp really packs a punch. Depending on what you're hooking up to that amp I would defenitely recommend it to you. - Ryan in Alaska
Feb 15, 2011 | Rockford Fosgate P7001BD Car Amp
Wiring diagram
run them in sereis hooking them all up together and bridging the amp
Jul 22, 2009 | Rockford Fosgate Power 1500BD Car Audio...
5 stage band pass sub box, 1 sub stolen, box built to spec subs
I would try walling it up unless you are going to buy 2 brand new subs. the problem is the older power subs had such small magnets so they needed alot less air space inside the box. Unless you can find the EXACT subs this box was made for I would recommend chopping it and doing a single sub. if you try a replacement sub go with the 12" P1 series they are a close match for the power 12's of the past.
Mar 06, 2009 | Rockford Fosgate Car Audio & Video
"low impedance"
it is really hard on an amp to run it below recommendation or specs and most audio companies won't warranty if they catch wind. but i have not seen an amp last long or operate without cutting out when you do this.
Jan 30, 2009 | Car Audio & Video
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Sub hook ups
There's a lot more factors involved than that.
  • Power capability of the subs
  • Type/size of the sub box
  • Allotted space in the vehicle for the sub box
  • Voice coil impedance of the subs versus the capability of the amp
  • Etc.
Jun 19, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Car Audio & Video Logo
126 people viewed this question
Top Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
