When i turn swicth onto Cammera, LCD screen and view finder is black ,some time smears.Some time see a pictuer. Any things esle is Working good. When i turn swicth onto Cammera, LCD screen and view finder is black ,some time smears.Some time see a pictuer. Any things esle is Working good.
If your Sony DSC HX1 camera appears to be working, but you can't see anything through the viewfinder or LCD screen, there are a few possible causes for this issue:
1. Display Settings: Check the display settings on your camera. There may be an option to switch between the viewfinder and the LCD screen. Make sure the correct display mode is selected.
2. Viewfinder/LCD Switch: Some cameras have a switch or button that allows you to toggle between the viewfinder and the LCD screen. Ensure that this switch is in the correct position for the display you want to use.
3. Display Brightness: It's possible that the brightness of the viewfinder or LCD screen is set too low, making it difficult to see the image. Check the camera's settings menu for options to adjust the brightness or contrast of the display.
4. Faulty Display: If the above steps don't resolve the issue, it's possible that there is a problem with the camera's viewfinder or LCD screen. This could be due to a loose connection, a damaged cable, or a malfunctioning component. In such cases, it's recommended to have the camera inspected and repaired by a professional technician or the manufacturer's service center.
5. Power Saving Mode: Some cameras have a power-saving feature that turns off the display after a certain period of inactivity. Check the camera's power-saving settings and make sure the display timeout is set to a reasonable duration.
If none of these solutions work, it's best to consult the camera's user manual for specific troubleshooting steps or contact Sony customer support for further assistance. They will be able to provide you with more detailed guidance based on the specific model and issue you're facing.
Did you try pressing the display button several times? in both viewing mode and record mode? Cycle through all display modes, s you get used to the button, so it does not trow you off when it happens again.
Click the "disp" button. The display of the camera has been turned off in the LCD screen but you can still use the viewfinder, this functionality is just for those who prefer to use the viewfinder instead of the LCD screen.
You get to the viewfinder by putting an eye to it. The Rebel XT works as SLRs have worked for half a century, showing you the image through the viewfinder. Only more recent dSLRs have a Live View capability, allowing you to use them as point&shoot cameras by viewing the image on an LCD.
The D40 works the same way SLRs have worked for the past half century. Only recently have dSLRs acquired a "Live-View" capability, where you see the image on the LCD monitor instead of through the viewfinder.
I realize this probably wasn't the answer you wanted to see, but that's the way it is.
Your Canon S1IS camera has defect in CCD Sensor and Canon will repair it Free Of Cost. For details, please click Canon CCD Notice and confirm by giving call to Canon.
Regards,
LCD = Lousy Camera Device? Get used to using the optical viewfinder. The LCD is great for reviewing images after you've taken them, but it leaves a lot to be desired as a viewfinder. Keeping your camera steady is no small feat at the best of times, but being forced to hold the camera away from your body to view an image through the LCD adds a new level of instability to the picture-taking process.
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
do u see when u rec something is it blank as well
