I don't know what the code means (F21)?
How do I solve this problem?
Clean the drain -here are a few postings i used to fix my Whirlpool ****-eettt (Duet)10 minutes ago. google whirlpool duet there is a 5 min video by jim that walks through the whole gig. 3 screws a twist & you're done your correct so lets fix it...take bottom acess panel of ..theres three screws,,,ok ready clean that pump filter it right in front of you twist it out always unplug first unplugged good,,now while your down there with the filter out,,check booth black hose to make sure theres no coin or hair clips while you have it open,,onthejob
error code f 21 is coming up please help
F21 is a drain problem.However, in the manual it is suggested that either the hose is kinked, the drain hose is frozen or it is clogged...what happens if none of the above are the issue and I'm, still getting the error code F21?
