Sharp Wizard OZ-290 Logo
Anonymous Posted on Mar 22, 2009
Where is "menu"?
I get a "menu" on the telephone list, but no menu on the "clock" screen. I need menu to set the time. Please advise.
Gregory
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
149
Points
I looked at another question and discovered the "2nd" on the screen. That fixed it.
Thanks,
Gregory
1helpful
Uniden phone XDECT SSE47 When setting date & time for daylight saving time screen reverts to standard time after a call is made. How do I stop this reversion?
Do you have the time adjustment set to Caller ID? If so, the time is being reset when your phone connects to the telephone company computer. To set this see the Advanced Setup options. Make sure that the phone system is in standby when you press the Menu/OK button to access the menu system. See page 17 of the manual for the information on the Advanced Setup options. The manual is available here: https://uniden.com.au/wp-content/uploads/2017/07/SSE_47_OM.pdf .
I hope this helps. My guess is your telephone provider either hasn't updated their clocks or otherwise is giving faulty time information.
Have a Whirlpool over-stove microwave. Can set time but then it scrolls between AM & PM. Cannot find how to set the AM/PM portion, and completing the time set.
Which microwave model do you have? Most of the Whirlpool microwaves that I know only have a 12-hour clock. They do not indicate AM or PM. To set the ones that I know, press Clock. Type in the current time in a 12-hour format. Press Clock again. The only model that I find quickly that has an AM/PM option is the GH7208XR. On that model, start with the main menu displayed on the LCD screen. Touch Settings and Info. Next press Clock. Then press Adjust Time. Follow the instructions to set the time and the AM/PM setting. I'll assume you use the +/- buttons. To hide the clock, get to the Clock Screen. Press Adjust Time and Hide Clock to return to the main menu. See these two pages of the manual for this model: https://www.manualslib.com/manual/190817/Whirlpool-Gh7208xr.html?page=9#manual and https://www.manualslib.com/manual/190817/Whirlpool-Gh7208xr.html?page=12#manual
Current Whirlpool over-the-range models sold in the US are listed here: https://www.whirlpool.com/kitchen/cooking/microwaves/over-the-range.html . Other Whirlpool appliance manuals are available from the Owner Support page: https://www.whirlpool.com/services/manuals.html.
I hope this helps. Please add a comment with the model number for a more accurate information on setting the clock. The model number should be inside the microwave on the rim. Usually it's on the bottom of the door frame near the door hinge.
I have a Panasonic Telephone KX-TGCA21. How to reset the Date and Time
The handset is KX-TGCA21. This handset communicates with the Panasonic KX-TG403SK or the KX-TG433SK phone systems.
To set the date and time, press Menu (the right hand soft-key below the LCD screen) on one of the handsets when the system is in standby (no calls on any handset). Then press # 1 0 1 . Type the current date (month, day, year) using two digits for each. So today would be 06 15 18. Press OK, again the soft-key. Then type in the current time, again with 2 digits for the hour and for the minutes. Use a 12-hour clock if the phone is set for English. In this case, press * to select AM or PM. If your system is set for Spanish language menus, use a 24-hour clock. Press Save (with the appropriate soft-key). Then press Off to exit the menu system.
If you want to navigate through the menu without typing # 1 0 1, choose Initial Settings, press Select. Then choose Set Date and Time. Press Select. Finally choose Date and Time and press Select again. Enter the date and time as above.
The first method to set the date and time is given on page 13 of the manual. The second is shown in the menu tree on page 22. The manual is available from Panasonic here: ftp://ftp.panasonic.com/telephone/om/kx-tg403_en_om.pdf .
I hope this helps.
1helpful
Explain how to set the date in the bottom right corner of my computer screen
  • Double click the time display on the bottom right of the computer screen to open the date and time properties box. Use the tabs to access settings for time, date, time zone and Web-based time updates.
  • 2 Set the clock for the correct time zone. Click the "Time zone" tab. Click the drop-down menu for time zone choices. Click the time zone choice for your area. Click a check in the box for automatic updates on daylight saving time changes. Click the "Apply" button, then the "OK" button.
  • 3 Set the correct date. Click the "Date and time" tab to show clock and calendar settings. Click the drop-down menu displaying the name of a month to change the month. Use the up-and-down arrow keys to change the year being displayed. Click on a date on the calendar image to set the date. The time can be manually set on this page also.
  • 4 Set the current time. Use the up-and-down arrow keys next to the numeric time display on the date and time page to manually set the clock. Click "Apply," then click "OK" to confirm date and time settings.
  • 5 Click the "Internet time" tab to use a Web-based clock for updates to automatically correct the time. Click the "Server" drop-down menu for listed Internet time sources. Click a check mark into the check box for automatic synchronizing. Click the "Update now" button, then click the "OK" button.
I just purschased an Lg 26LV2500 and I can't get the military time off the screen when it is first turned on. I've set the clock manually with the month, date, and year and I've set the hour...
When you click on the clock icon the clock setting menu comes up scroll down to the bottom of the list if it is available it is two lines below the options on screen and change it to am\pm press return go back up the list and click option to set clock set clock press back /return then exit
The phone says no phone line, and i dont have a dial tone. cant call out and cant get calls coming in
Model LS6305: How to register a handset:
  1. Place the non-registered handset in the telephone base or charger. If 1.Press FIND HS on base 4sec and 2.Then press # on handset do not appear alternately on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
  2. On the telephone base, press and hold FIND HANDSET for about four seconds until the red IN USE light on the telephone base turns on.
  3. Remove the handset from the telephone base or charger and then press # (pound key). It displays Registering...Please wait. It takes about 60 seconds to complete the registration. The handset displays Handset X Registered and you hear a beep when the registration process completes.
  • If the registration fails, the handset displays Registration failed for a few seconds, then 1.Press FIND HS on base 4sec and 2.Then press # on handset alternately. To reset the handset, remove it from the telephone base or charger and place it back in. Try the registration process again.
Model ip8300: How to register a handset:
  1. Press and hold FIND HANDSET for at least 10 seconds on the telephone base. The VMWI and LINE IN USE lights will blink alternately indicating that the telephone base is in registration mode.
  2. To display the telephone feature menu, press the Menu softkey from the main idle screen.
  3. Press the up, down, left and/or right NavKeys to choose Registration Settings then press the Select softkey or center NavKey/SEL.
  4. Press the up or down NavKey to choose Handset Settings then press the Select softkey or center NavKey/SEL.
  5. Press the up or down NavKey to choose Register to Base then press the Select softkey or center NavKey/SEL. A list of locations for assigning telephone bases will be displayed.
  6. Press the up or down NavKey to choose an empty location and press the Register softkey or center NavKey/SEL.
  7. The handset will display Searching while it searches for the telephone base. If the search is successful, a code from the telephone base will be displayed. To register the handset to the telephone base, press the Register softkey.
  8. In the Enter PIN box, enter the system PIN. The default PIN is 0000. Press the Apply softkey.
  9. Handset registered will be displayed when the registration process is complete. The screen will return to the registration settings menu. Press OFF to return to the idle screen.
Model ip8301: How to register a handset:
  • Before registering the handset with the base station, press the FIND HANDSET button in the base till the VMWI and LINE IN USE lights blink alternatively. When the lights start blinking, register the handset. The default PIN for registering the handset with the base station is 0000.
  1. Press Softkey Menu from Home screen
  2. Choose the Settings icon from Menu screen and press center Navigation key/SEL to display the settings menu options.
  3. Press the up or down Navigation Key to choose the Registration Settings menu option and press the center Navigation key/SEL to select.
  4. Press the up or down Navigation Key to choose the Handset Settings and press the softkey Select to select.
  5. Press the up or down Navigation Key to choose the Register to Base and press the softkey Select to display a list of available base stations. Choose a base station from the list and press the softkey Select to select.
  6. The handset will search for the Base within its range. During this time, the searching screen will be displayed.
  7. If the search is successful, the Base station number of the base will be displayed.
  8. Press softkey Register. Enter the PIN and press softkey Apply to save and subscribe to the base station.
  9. To cancel the entire operation, press OFF key anytime.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1helpful
Red flashing clock in screen
Do you have the self-timer turned on? You could go into the camera menu and find "reset" to return to default settings.
1helpful
Change time
follow the steps below:
  1. Touch the center of the screen to bring up the "Main Menu" window. A list of options will appear on the screen.
  2. Tap "Change Preferences" and "Set Clock" to bring up the "Set Clock" window. Several additional options are available in this window.
  3. Press the "Sync" button on the screen to set the time on your GPS unit. The TomTom One will use information from the satellites to correct the time on your GPS unit.
I hope this helps to solve your problem.
Good luck.
How do I set the time on my Pioneer RT500?
Hi!
Please follow the instructions given below... =)
Setting the clock
The clock is set to the correct time automatically, but it
can also be set manually. The clock can be set for
daylight saving time and time zone.
Preparation:
• Turn ON the TV and set it to the video input mode.
• Select “CLOCK” from “SYSTEM SETUP”. For the
procedure, see steps 1 to 3 in “Using the SETUP
MENU”
1 Press SETUP while the DVD and video tape is
stopped.
The SETUP MENU screen will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
SETUP MENU
ENTER/
SELECT ENTER RETURN BACK SETUP END
SELECT
2 Press  or  to select the desired menu and
press ENTER.
The submenu screen of the selected menu will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
LANGUAGE
PARENTAL
CLOCK
DISC SETUP
OTHER
SETUP MENU
3 Press  or  to select the desired submenu and
press ENTER.
The screen for the selected submenu will appear.
CLOCK (manually)
You can manually set the date, year and present time
with the remote control.
Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
1 Select “CLOCK” and press ENTER.
01/01/04 12:00AM
2 Select the desired items using  or  (month,
date, year, hour, minute and AM/PM) then press
ENTER.
3 Press  or  to set the value of the selected
item.
• For the minutes, press  or  once to set the time
minute by minute, or hold down either of buttons
for several seconds to set the time in 10-minute
intervals.
10/30/04 10:200AM
4 Repeat steps 2 and 3 to set the date, year and
present time, and press ENTER. The SETUP MENU
will close.
This completes clock time setting.
AUTO CLOCK
You can automatically set the clock by turning “ON” the
AUTO CLOCK function.
When you want to set the auto clock function to “OFF”,
select “AUTO CLOCK”, press ENTER and select “OFF”
from the list.
Auto clock setting
Preparation:
You must connect the antenna or cable before connecting
the AC cord to the power source.
Wait 30 minutes with the power turned off, after the
antenna or cable is connected, for the auto clock
feature to activate.
After the clock is set automatically, you may have to set
the time zone and daylight saving time. (See page 26.)
Press STANDBY/ON to turn on the DVD/VCR after the
auto clock operation completed.
• When shipped from the factory, the “AUTO CLOCK”
option is set to “ON” position.
• If you turn the DVD/VCR on during auto clock
setting, the clock is not set.
• After a power failure or disconnection of the power
plug, the clock setting will be lost. In this case, wait
30 minutes before turning the DVD/VCR on.
• With cable box connection, if the auto clock setting
is unsuccessful, select the PBS channel carrying
the XDS information, then turn the DVD/VCR off.
After 30 minutes, turn the DVD/VCR on.
• If the clock is not set automatically, set the clock
manually.
STANDARD TIME (Time zone)
In the rare event that you live within the broadcast range
of two stations in two different time zones, the DVD/VCR
may recognize the wrong station for the auto clock set.
To correct the situation:
Select “STANDARD TIME” and select the time zone from
the list below.
Selectable time zones and correction times
ATLANTIC: GMT – 4 hours
(GMT: Greenwich Mean Time)
EASTERN: GMT – 5 hours
CENTRAL: GMT – 6 hours
MOUNTAIN: GMT – 7 hours
PACIFIC: GMT – 8 hours
ALASKA: GMT – 9 hours
HAWAII: GMT – 10 hours
AUTOMATIC: AUTO SET
Note
• When shipped from the factory, the “TIME ZONE” is
set to “AUTOMATIC”.
• After making the auto clock setting, in some cases
the clock may display another time zone. You can
correct the clock by selecting your time zone
setting above.
• When the clock is not set or you set the clock
manually, the time zone setting is not available.
DAYLIGHT SAVING TIME
You can set the clock to daylight saving time automatically
or manually.
To select daylight saving time, select “DAYLIGHT
SAVING TIME” and select “ON”, while to cancel the
daylight saving time, select “OFF”.
ON: For manual setting (forward 1 hour)
OFF: For manual setting (back 1 hour)
AUTOMATIC: For automatic setting (read XDS in
the signal)
Note
• When you want to set daylight saving time, on the
first Sunday in April you set it to “ON”, and on the
last Sunday in October you set it to “OFF”.
• When shipped from the factory, the “DAYLIGHT
SAVING TIME” option is set to “AUTOMATIC”.
• When the clock is not set, the daylight saving time
• When there is no daylight saving time in your area,
always select “OFF”.
Top Sharp Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Ngoro
john h
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
