Buy the flat blade from herehttp://www.amazon.com/gp/product/B002YEP...Buy the flat blade from here
http://www.amazon.com/gp/product/B002YEPGOU/?ie=UTF8&tag=atoyhocom-20&linkCode=ur2&camp=1789&seller=A1KB97A5SK5WKE&creative=9325&sn=amazingearth
You can't post conmments that contain an email address.
1. First pry out the 4 black rubber feet on the base with small screwdriver and unscrew the 4 cross head screws revealed below.
2. Remove this black base to reveal the inner black base Unscrew the cable clamp - 2 screws and the 3 screws that retain the remaining black base to the body of the bullet - slide it off over the power cable.
3. Turn the bullet the proper way up and pry out the 3 white rubber bumpers with a screw driver blade that are set inside for the cup to rest on - each is located with two rubber pins. Once all 3 are removed you will reveal 3 more cross head screws - these countersunk - remove all 3 and then the internal motor will be free to lift out through the top of the Bullet casing.
4. Its possible to slip out the 3 white plastic sliders - taking care to note how they seat each on a small spring to cleanup both the slides and the sliders.
To re assemble step by step in reverse - noting to align the motor cable with the cutouts on the bullet base.
I posted the reply pasted below on how to take the Bullet apart - really not difficult once you know where the hidden screws are apart. Once apart it easy to see where the power cable terminates and should be easily possible to connect in a new cable in its place.
Yes its easy to take the Magic Bullet apart.
Your black plastic blades, which are on the bottom of the black blade attachment, that interlock with the blades on the base of the machine may be worn down. When the bullet is turned on and these are not interlocked properly they rub on each other causing the interlocking part to wear down so it no longer catches to turn the blades. As far as I know the only solution for this is to get a replacement part.
On the website they are offering a package where you can get a new blade, but it comes with a bunch of other things. The website is: http://www.buythebullet.com/ and this is the package they offer:
Deluxe Upgrade Kit
Upgrade your Magic Bullet! You can save even more time and trouble in the kitchen with the Magic Bullet Deluxe package, which includes 2 additional Tall Bullet Cups and 1 additional Short Bullet Cup, plus 3 more Stay-Fresh Re-sealable Lids.
Using the Magic Bullet in our own homes we've found these extra Bullet Cups and Lids come in very handy when the others are being used to store leftovers in the fridge. Plus, you also get 1 extra Cross Blade.
And since this is the blade you'll use the most, it's nice to have an
extra one around when the other is in the dishwasher. If you have a
family at home, the Magic Bullet Deluxe is a must! Upgrade your Magic Bullet today for just one payment of $29.97 (plus $6.99 shipping and handling).
http://www.buythebullet.com/ This is the website and you can go on and order a new blade but it comes with other things and costs $30. The package is called the deluxe upgrade kit.
I NEED THE CROSS BLADE ONLY ALSO WHERE CAN WE GET ONE FOR THE MAGIC BULLET
