Iam failing to remove this nmti ang i cant even configure the port and frame relay resource because of that problem
Hi Christina,
If you have NMTI connections on the FRE, first you need to disconnect the frame relay path, this has to be done by logging into the FRE and disconnect it using the DLCI number of the path, once all the paths has been disconnected you can then log into the 3600 node and disconnect the Frame Relay link. After all is cleared you can create the new link and paths again
RegardsLen
Hi Christina,
The problem come up or happened because the link (E1/T1...) problem or 3600 series going down e.g power down etc. The effect of it sometimes influenced the circuits mainly the circuits made by nmti software via hyperterminal, 4601A even 5620 NM (integrated NMTI).
To solve the problem first you have to clear or de-configure the configuration/cross-connect via nmti and than you connect again the circuits. Please using Alcatel 5620 NM GUI to make cross-connection or circuits (Circuits Switch Data).
Regards,
jhadori
