Question about HP Pavilion dv4000 Notebook
Quick touch my quick launch buttons which located above the labtop keyboard is not working at all using windows 8 .. it's not giving any light.. only when i open my pc it keep working and every thing is lighten up till it begin the windows 8 it's not working.. i downloaded the new drivers and BIOS driver up date.. i updated the bios then installed the new quick launch driver .. but i got no thing ... please help
Larry Ng
  • HP Master
  • 5,971 Answers
Got nothing?, (means PC is dead or just key buttons dead)
tell what works and not, we can not watch you or it. please
Series:
DV4000 is a series of LT. it has a full & real model stated on its service tag, only THAT works,
so how'd it get w8? there? (bought FROM MS or HP?????)
why mess with BIOS> ? if this fails it bricks the PC.
(if you must flash always flash using the usb stick way. (freedos)
not only that using the wrong model to flash, HP sold this series with AMD and Intel processors. oops......
next time before doing such big thing ask, hp first?
both model and p/n matter, when doing updates or buying parts.
big time!
learn that HP page, the exact model and OS must be selected
or it shows you the WRONG BIOS and wrong driver and wrong HP APPS. for a fact.
here is the series page, dangerous, imo
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-dv4-4000-entertainment-notebook-pc-series/5082208
use the real page by using real models #
BIOS101
pick any LT. even yours.
the PC can have 6 different network chips used in the long production run.. and GPU and other features, very different.
in your case even the CPU vastly different. amd/intel
so giving that fact, picking the right BIOS binary can be very hard.
best of all why not ask HP before even walking the path.
https://h30434.www3.hp.com/
Posted on Jul 28, 2017
5 Related Answers
Anonymous
SOURCE: hp nc6320 laptop
your hard drive is locked. try to remove the drivelock in the BIOS
Posted on Jun 13, 2008
Filip Eastman
  • 477 Answers
SOURCE: BIOS help
Hello
you need to download right bios and burn it to a CD, then you need to boot from that cd.
plz give me the exactly model of your computer? and I will search for the bios update.
you can boot from the recovery cds before you have "installed" the right bios.
let me know the exact model and I will give you more instructions what todo.
if you know how to burn and how to get the right bios go here and input your model.
else let me know.
hp drivers
Posted on Oct 09, 2008
Joed911
JDTec
  • 4338 Answers
SOURCE: wrong bios
The # 443694-001 refers to the cd set. You need to know which DV9000 you have. On this link you will see all the DV9000 models.:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=DV9000+443694-001&submit.x=6&submit.y=4
You will need to use a friend's computer for the following.
Once you find the correct firmware, You can make a bootable CD by using Nero or Roxio burning software,these are the most common on computers nowaday.Once you make the bootable CD, you will have to set your laptop to boot from the CDROM. Then boot the CD you made and run the firmware update.
I don't believe you would be able to get a USB flash drive to boot in this condition.
Good Luck
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Oct 14, 2008
zohail
Shoaib Rais
  • 1223 Answers
SOURCE: No BIOS display
i found out !
its a display device driver problem ur display device may be nvidia first update ur display device driver first if problem doesnt resolve then update ur BIOS but avoid it if problem goes away thru vga driver pls rate me FIXYA for help
see this ur problem will sove 100%
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01604982&lc=en&dlc=en&cc=us&product=3376900&rule=16783
and this
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01534678&lc=en&dlc=en&cc=us&product=3376900&rule=16783
Posted on Mar 27, 2009
efs_perpends
efs_perpends
  • 1997 Answers
SOURCE: quick launch volume button turns red when Laptop boots
Right Click the Start button, choose properties, then select the taskbar tab. Remove the check mark next to "show Quick Launch".
What are you using for your media player?
Which OS are you on? When does the button turn red?
Posted on Mar 30, 2009
How to unlock the touch pad
There should be a touchpad on/off button on the top row of lights above your keyboard. It is a square icon, tbh it looks like a small touchpad. If this doesn't work there may be a problem with a driver. In which case go here - http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=3355636&
then choose your operating system. First try the quick launch buttons driver, then try the synaptics driver. Post back if this doesn't help
Mar 14, 2014 | HP Compaq 2510p Notebook PC
Hpp dv6 1115ee quick luanch notwotking
This model doesn't officially have Windows 8 support. That would be why the quick launch doesn't work. Also quick launch I believe for HP is only supported for Win 8 Pro and Enterprise versions, not the consumer version.
Jun 08, 2013 | HP Pavilion Computers & Internet
My dv 3 was originally running Vista-64, however because off the huge number of bugs I was encountering I decided to upgrade the OS to Windows 7 32-bit. It runs like a dream and ha been a nearly flawless...
There are some items that will need to be updated to the new OS. I am including a link to HP's website. I would look at the driver section (there is new drivers for the quick launch), and the software solutions. In fact since these will be the most updated driver and software patchs for Windows 7, I would probably download most of it. Hope this helps and fixes the glitches you seem to be having.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=4062&lc=en&cc=us&dlc=en&sw_lang=&product=3860372
Jul 22, 2011 | HP Pavilion Dv3-1075us Notebook
My hp 4520s probook's mouse pad got locked accidentally, and it's not unlocking by double tapping on the light button on the mouse pad. please help me with this asap.
First, try double tapping the light again. You may have just mis-tapped.
Next try restarting the laptop. Certain laptops re-enable the track pad on restart so long as a USB mouse isn't connected.
If that fails, navigate to the Mouse Settings on your PC and re-enable it there. If you have a USB mouse you can use that. If not, you can use the keyboard. Windows Key will launch the Start Menu, arrow keys can highlight options, Enter will click on them, Control+Tab and Control+Shift+Tab will switch tabs (in a window that has tabs).
In Windows XP and 7 (and probably Vista), Mouse Settings is located at Control Panel > Mouse > Settings.
Mar 21, 2011 | HEWLETT-PACKARD ProBook 4520s
Dell Studio 1737 --power button is broken. Is there another way to power it on?
friends ... i discovered a way that you can power on the dell studio 1535 easily ...
first of all you know the power button .. it's now working ( or stuck )
in the other side of the labtop, there's a wifi button, when the labtop is already shutten down, you can press it and it will give a light then shuts down the light in the button, that means that it gives power, now to complete the process you should know the touch button in the left side that means Dell MediaDirect ( touch control button of the dell studio ) ..
ok, Now, do exactly what i'm telling you :)
1- when the computer is shutten down, plz press the wifi detector button one press
2- it will give a light then shuts then gives light again for a longer time.
3- when giving the first light for a short time, do not wait, press the media touch button quickly, continuesly and separetly.
it it doesn't work ... try it for many times tell you know when exactly to press the media touch button
then you'll see that the labtop starts as if it was in sleep :)
Feb 10, 2011 | Dell Studio 1737 Laptop
The touch bar on the keyboard for controlling sound and wireless does not work i've downloaded a driver previous to fix this, but can't find it
Hi! You may click here to download the driver of the touchbar of your system. Choose the keyboard section where the hp quick launch buttons are located. Thanks for visiting FixYa.com!
Jun 09, 2010 | HP Compaq 6710b Notebook
Hp laptop touchpad for cd and wireless conet. stopped working
I get it. The multimedia keys above the keyboard is not working. If I'm right, check if you have installed the HP Quick Launch buttons software. If not check in C:/SwSetup and you'll find a folder. Install the application and check if the buttons are working. If not, post back
Jun 24, 2009 | HP Pavilion dv4000 Notebook
Quick launch volume button turns red when Laptop boots
Mar 30, 2009 | HP Pavilion dv4000 Notebook
Light-up volume bars on the hp pc notebook dv7 1132nr
Hi Folks....
If you are talking about the Quick Launch buttons of the Notebooks from where we usually increase, decrease or mute the Volume, the lights will be still and will not increase or decrease with the increase or decrease in Volume.
However, you do have a utility which should be preinstalled in Notebooks called HP Quick Touch which shows the bars on the Display when the volume is Increased or Decreased  using the Quick Launch buttons. This application is not compatible with Windows Vista 64 bit edition.
The HP Quick Touch application is available for download from the link below :
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38358.exe
Save the file in the Notebook and double click it once the download is completed to install the application.
Hope this helps....
Dec 20, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
42 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
