More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
the microwave it self is working but its just not getting hot would the magnetron be expensive to fix where would i find the magnatron and high voltage fuse please help
can u tell me where to locate the magnetron and hi voltage fuses
food not getting hot
