Question about Canon MV530i Mini DV Digital Camcorder
Sd card 4gb error - Canon MV530i Mini DV Digital Camcorder
Posted by Thomas Cloud on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Your new 4GB card is actually an SDHC card. The MV530i works with SD cards, 2GB and smaller. It will not work with SDHC cards.
Posted on Jun 08, 2013
1 Related Answer
jgroves705
Jeffrey Groves
  • 573 Answers
SOURCE: i get error when initilize sd 4GB. "card error"
Try connecting the SD card to your computer and formatting it that way.
If this does not work, then the SD card may have failed.
Check the contacts on the SD card to make sure there is no debris on them.
Posted on Dec 20, 2010
What's your problem?i put a 4gb memory card in my canon SD 200 and it says error why
The SD200 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in this camera. You need to use SD cards, 2GB and smaller.
Mar 05, 2012 | Canon PowerShot SD200 / IXUS 30 Digital...
I get error when initilize sd 4GB. "card error"
Dec 20, 2010 | Canon MV960 Mini DV Digital Camcorder
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
May 15, 2010 | Pentax Optio S50 Digital Camera
Inserting either a 4Gb or 8Gb SD card results in a "Memory Card Error".
The S4 accepts SD and MMC cards. SD cards max out at 2Gb. The 4Gb and 8Gb cards are actually SDHC (Secure Digital High Capacity) cards, not SD cards, and thus will not work in devices designed for SD cards. Compatibility goes only one way--SD cards will work in SDHC devices but not the other way around.
Dec 27, 2009 | Pentax Optio S4 Digital Camera
Just put in new san disk 4gb memory card and receiving error message - memory card error. I unlocked memory on card itself (that little gray sliver that goes up and down) What gives
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 21, 2009 | Canon PowerShot A610 Digital Camera
New 4gb sd card will not work. card error
Is the slide switch in the unlocked position? Are you formatting it in the camera? Are the card contacts dirty?
Dec 07, 2009 | Casio Exilim EX-Z40 Digital Camera
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Micro sd card not working
I'm having the same problem with a Transcend 4GB microSDHC card / microSD adapter. I have also found it probably has something to do with the card reader...either the card reader is an SD card reader trying to read an SDHC card OR the card reader is not able to read high-gigabyte SD cards (over 1 GB in some cases).
Jan 23, 2009 | SanDisk 4GB microSD High Capacity Memory...
Card error
Hi!
I wish what I'll be saying will resolve the problem. Unfortunately, your camera can only support up to 1GB of SD card. That's the reason why the 4GB card is not working.
Here's a screenshot of the details regarding your Polaroid camera.
I hope that helps.
Good luck and have a nice day!
Nov 27, 2008 | Polaroid I533P Digital Camera
Canon MV530i Mini DV Digital Camcorder Logo
80 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
