Question about Norelco 8140XL Electric Shaver
Norelco 8140XL motor gear assembly
I bought a replacement motor gear assembly for my husbands Norelco 8140XL and was excited when it arrived only to find out that there are no repair manuals on how to replace these. Can you help?
Posted by Sherril Mitchell on
shaveroutlet.com
  • Norelco Master
  • 1,645 Answers
You will find partial instruction to disassemble the shaver at the link below. You will also need to remove the gear plate by removing the two screws in the hair chamber. Then just disconnect the wires from the motor by pushing in on the small metal release next to the wires on the motor while pulling on the wires
https://www.youtube.com/watch?v=rGD84BfKxAE&feature=c4-overview&list=UUc_zJiCUI8mpLyYlwCxo8IA
Posted on Aug 07, 2013
3 Related Answers
Anonymous
  • 3 Answers
SOURCE: Replacing Heads for 8140XL Norelco shaver
Same thing happened to my father's shaver. After working on it for about 30 mins, this is how I fixed it. You need to start with the top silver piece/cover. Turn it over so you see inside of it. Drop the 3 screens into the holes upside down (so they face out). You need to rotate the screens until they sit as low as possible. Now drop in the 3 blades, again sharp side down. There should be a triangular piece with 3 circles attached to it. One side is gray, and the other side has a black triangular piece. If you look closely each leg of the black piece has a tiny picture of a lock and an arrow. Rotate the black piece in the opposite direction of the arrow. Place the gray side down lining it up with the three blades. Now rotate the black piece, it will lock into position, and hold the blades in place! Finally, the silver head has a little hinge on one side. This hinge is flexiable. Bend it to a 90 degree angle, and slip it into the notch on the top part of the main body of the shaver. Close the head part, in my father's shaver I had to press a lever in the front to snap it into place.
Hope this helps!
Posted on May 13, 2009
brector3
shaveroutlet.com
  • 1645 Answers
SOURCE: Why do the plastic drive
If this is a repetitive problem for you, there must be a reason. Most likely, the blades are getting jammed and this is causing the tips of the gears to twist off. To prevent this from happening, make sure that you disassemble the shaver heads and thoroughly clean the teeth on a regular basis to prevent them from getting clogged solid. Also, make sure that you are protecting the delicate combs of the shaver head to prevent them from getting damaged. If the comb gets damaged, the teeth on the blade will lodge in it and this can cause the gear tip to break off.
You can replace thesebroken gears. You will find the required part at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-8100-series-motordrivegear-assembly-p-608.html
Posted on Oct 04, 2010
saeed_fane
saeed_fane
SOURCE: Norelco 8100 Series Motor/Drive/Gear Assembly
I have a smart touch xl hq9190 shaver, its gear is broken, can I buy Norelco 8100 series gear and use it for my shaver, is it work? If not, what kind of gear I shoud buy for my shaver?
Posted on Nov 11, 2012
Norelco 8140xl new blades doesnt shave
Did you use part HQ9 for your replacements? Norelco makes many different replacement heads and only one type is correct. The correct type for model 8140XL can be found at shaveroutlet.com below
http://shaveroutlet.com/norelco-philips-hq9-replacement-heads-p-252.html
1helpful
2answers
The gear tips are not available from the manufacturer. You will have to replace the whole assembly. Your other option is to but a used model of the same type off of ebay and take the gear stems off of it.
Will my norelco 8140 xl electric shaver work with the electrical system in Israel (220v) without a converter? Will I need an adapter?
Yes. the charging cord for model 8140XL have a built in voltage converter and can be used with 100-240V
Why do the plastic drive gears underneath the shaving head keep breaking off? Thisis the third Norelco 8140Xl this happened to.
Where can I get the stems on the motor / gear assembly ( 4222 036 1290) for norelco 8140xl shaver
You will find this item at shaveroutlet.com. See link below<br /> <br /> <a href="http://shaveroutlet.com/norelco-8100-series-motordrivegear-assembly-p-608.html">http://shaveroutlet.com/norelco-8100-series-motordrivegear-assembly-p-608.html</a>
Norelco 8140XL Electric Shaver Logo
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ADMIN Canada
ADMIN Canada
Thomas Perkins
Thomas Perkins
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
