I have a new acer lap top with windows X P and i am trying to install the software for my kodak easy share digital camera c340 but computer does not seem to recognise the camera connection or the cD rom. I dont know what to do as I am a complete novice
You can also try installing the software online by using this website www.kodak.com/go/easysharesw , once you're done make sure that the camera is turned on befor connecting to your computer.
This is the instructions on how to remove existing ESS system in order for you to start on a fresh.
Please follow the instructions:
Uninstall Easy Share software:
Select Start > Settings > Control Panel > Add / Remove Programs. For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs.
Select Kodak Easy Share software.
Select Remove (or select Change, and then select Remove).
Run the Clear utility:
Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
Click the Download button, and then follow the on-screen prompts.
After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
I?m not sure if you?re fault code is showing on the computer, Easy Share Software, or the camera itself. Therefor I will list 2 possible solutions: If the fault message is on the LCD on the camera: There is no firmware available online for this camera model. Therefor you do need to set up a "repair" with KODAK directly. An Out of Warranty repair for this model for this fault is about 88 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price. In order to arrange your repair/Trade up: Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490 If you're experiencing this fault code on the computer: Please do a Clean Install on the Easy Share Software: Please follow the instructions: Uninstall Easy Share software: Select Start > Settings > Control Panel > Add / Remove Programs. For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs. Select Kodak Easy Share software. Select Remove (or select Change, and then select Remove). Run the Clear utility: Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear Click the Download button, and then follow the on-screen prompts. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
It is not possible to email directly from the camera.
If you're experiencing emailing difficulties directly from the Easy Share Software:
Please do a Clean Install on the software:
Possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember your USB cable is covered under the same warranty as your camera, so remember your serial number when calling: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
If you suspect it could be directly related to your software.
You need to follow the instructions:
You need to upgrade your version to be compatible with Windows Vista: Please do a Clean Install on the software:
If this fault message is on your computer starting Easy Share Software: Please do a Clean Install on the software:
I?m not sure if you?re fault code is showing on the computer, Easy Share Software, or the camera itself. Therefor I will list 2 possible solutions: If the fault message is on the LCD on the camera: There is no firmware available online for this camera model. Therefor you do need to set up a "repair" with KODAK directly. An Out of Warranty repair for this model for this fault is about 88 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price. In order to arrange your repair/Trade up: Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490 If this fault message is on your computer, Easy Share Software: Please do a Clean Install on the software: Please follow the instructions: Uninstall Easy Share software: Select Start > Settings > Control Panel > Add / Remove Programs. For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs. Select Kodak Easy Share software. Select Remove (or select Change, and then select Remove). Run the Clear utility: Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear Click the Download button, and then follow the on-screen prompts. After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
when it goes to the installation wizard.... do you let it run long enough to see a screen that gives you a choice to repair or uninstall ?
quick fix for the errors that are shown in start up is the start menu.... run and type in msconfig in the box.... another window pops up. click on the start up tab.... unmark any reference to kodak.
connect to the web type in camera model (ex, Kodak.com) will bring up the web site of the camera go into software dept on the site and download on to your laptop for the model number of your camera. Hope this helps Clarabella
