IGN Entertainment (G60306A) Game Pad Logo
A
Anonymous Posted on Jun 08, 2013
Doop gamepad driver pc - IGN Entertainment (G60306A) Game Pad
Hi...I have the doop gamepad pc-wl but I have missed the cd of installation..what else can I do to make the controller connect with me pc nad play?thank you very much!!
seems you missed the driver/software you need just google and find the software you need and download ->install and enjoy the game. do not forget to give a positive responce if this works
try to gind the software you needed from CD on internet . download and install it it will fix your problem
Logitech f130 was recognized before but now is not working?
You should delete all drivers of your gamepad and reinstall it again. Try this first.
If this doesnt help, try to make your gamepad work on another machine. If it works somewhere else, your computer is now the problem.
4helpful
USB gamepad is not detected.
Get the latest dirvers from the manufacturers website and install it on your pc.After that connect the gamepad.It should work fine.
Code 10 error is due to incomplete drivers or driver malfunction
2helpful
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
1helpful
3answers
LOGITECH PRECISION USB GAMEPAD
It may sometimes work without drivers, but its recommended that you download the drivers and have them installed. That way you can also program the buttons for various functions if you want...
Cheers!
6helpful
3answers
PC gamepad drivers
IGN Entertainment (G60306A) GamePad
WHERE IS THE DRIVER FOR THIS GAMEPAD?
1helpful
2answers
Driver
see if this is what you need - http://drivers.softpedia.com/get/JOYSTICK-GAMEPAD-WHEELS-and-TABLETS/OTHERS/Gravis-Gamepad-Pro-10.shtml
Top IGN Entertainment Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you an IGN Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
