Kodak EasyShare C143 Digital Camera Logo
A
Anonymous Posted on Jun 08, 2013
Memory card unusable - Kodak EasyShare C143 Digital Camera
CameraR
Level 3:
  • Kodak Master 4,738 Answers
  • Posted on Jun 10, 2013
CameraR
Kodak Master
Level 3:
Answers
4738
Questions
Helped
1194603
Points
12483
This video provides troubleshooting steps for memory card problems.
1 Related Answer
Anonymous
  • 114 Answers
  • Posted on Aug 29, 2005
SOURCE: "Memory card is unusable"
This error message means that the memory card is slow, corrupted, or unreadable. Turn off the camera then insert a new memory card.
Why sd card memory card is unusable
Are you sure you have an SD card (2GB or smaller)? The C653 will not work with higher-capacity SDHC cards.
When i turn on my camera it says Meomory card unusable insert new memory card
Try formating the memory card using the camera's Menu - select format memory card.
My kodak 1073is camera keeps telling me to format my new sandisk sdhc memory card when I do it tells me to insert a new card
Please confirm the model # so that I can check whether the large capacity memory cards are compatible with your camera.
I have bought a new memery card 4Gm and tried a old one that worked in another camera it says unusable
If all memory cards did not work then the fault is in your camera, it needs to be repaired.
My old memory card all of a sudden reads unusable, So i bought a new one...and it still says unusable... what do i do? I have only had the camera for 4 months
Try putting the new memory card into the camera and format the card. If the camera doesn't accept that it has a memory card turn the camera off remove the battery and then after about ten seconds put the battery back in and turn it on and see if you can format the new card again. You should always format the memory cards in the camera, even though there is a delete for single images leave them on the card and format the card. Always format the card in the camera not the computer.
By deleting single images in on the card while in the camera it sets up little partitions and pretty soon the memory card is rendered useless. Formatting in the computer writes a little program to the card which the camera can not read.
3answers
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
