Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Washer will not drain on spin cycle, water stays in machine
Maytag stackable, washer will not drain on spin cycle. Everything else works fine. Any help would be appreciated as wife and three girls are pressing me to fix it.
Posted by doug_baird on
Anonymous
  • 686 Answers
You might have a broken pump belt go to www.repairclinic.com enter model number and scroll down to the red 100 click it and start looking for the pump part number 1480330. You'll have to lean this thing back far enough to see if it is your belt or maybe even go through the back of it.
Posted on Apr 06, 2009
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
The water in my stackable washer and dryer wont drain
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
2answers
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Washer won't drain or spin
YOU MIGHT BROKE THE DOOR SWITCH CHEC IT OUT FIRST... IT CAN BE BYPASS IF YOU WANT :) LET ME KNOW
1helpful
Kenmore stackable washer/dryer 417.97802792 won't drain
its your brushes on your motor or the motor itself but my guess is the brushes replace and enjoy
2helpful
Mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
1helpful
2answers
Lower washing machine function inoperative in Maytag stackable
rclasky check this one
http://www.fixya.com/support/t827165-maytag_model_lsg7806aae
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Maytag atlantis washer
Start by checking the belt by tilting the machine back and examining for wear, glazing and cracks, next pull the belt to make sure everything turns. Post back if this looks fine.
Top Maytag Washing Machines Experts
Robert
Steve
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
