US ROBOTICS 9106- Reset not working. It came on bridge mode. can not go on the panel 192.168.1.1
i want to get access on the control panel how should i do as the rest not working..and i dont know how to reset my modem from the bridging mode. i am not able to use my internt.
i have also try tht for several times but still its not working.. i did it for more thn 5 sec also.. quite few times ..do u have any other solutioni have also try tht for several times but still its not working.. i did it for more thn 5 sec also.. quite few times ..do u have any other solution
Does anyone has the circuit diagram,, of the modem..! this method also does not work..any one can help...more solutionDoes anyone has the circuit diagram,, of the modem..! this method also does not work..any one can help...more solution
You can't post conmments that contain an email address.
Re: US ROBOTICS 9106- Reset not working. Bridge mode
NOTE: To reset the gateway, insert a pin or paperclip to push the reset button. This will restart the gateway. If you press this button for more than 5 seconds, it will then reset the gateway’s configuration to the factory defaults.
The following default settings are present when setting up the gateway for the first time.
LAN port IP address: 192.168.1.1 WAN connection type: bridging WAN ATM PVC encapsulation: LLC Local administrator account name: admin Local administrator account password: admin Local non-administrator account name: user Local non-administrator account password: user Remote WAN access: disabled Remote WAN access account name: support Remote WAN access account password: support NAT and Firewall: disabled dhcp server on LAN interface: enabled WAN IP address: none
Please make sure you are connected with a cat5 cable to one of the lan ports and that you enter "http://192.168.1.1"
(don't forget the "http://" it's important).
Also set your network card to dhcp so it will get its IP from the gateway.
If that doesn't work I would have to say there is a mechanical problem with the unit (repair or replace)
Hope that helps...
TimThe following default settings are present when setting up the gateway for the first time.
WAN ATM PVC encapsulation: LLCLocal administrator account name: admin
This it there web access info page address: http://www.usr.com/support/9106/9106-ug/wui.htm
Hope that helps...
Tim
Read the manual!
The Bridge mode on stereo amplifiers is often misunderstood relating to actual operation and usage. In basic terms, when a 2-channel amplifier is operated in the Bridge mode, it is converted into a single-channel unit with a power rating equal to the sum of the power rating for each channel, at a load of twice that of the single- channel rating. For example, the CPX 1500 is rated at 750 watts RMS per channel into 2 ohms. The Bridge rating is 1500 watts RMS into 4 ohms (minimum load). Bridge mode operation is accomplished by placing the MODE switch in the BRIDGE position, using only the BRIDGE Speakon connector or the red binding posts for the output, and using the CHANNEL A input. All CHANNEL B input func-tions are defeated and serve no purpose now. Bridge mode operation can be used to drive sound distribution systems in very large public address applications. Another common use for the Bridge mode is in subwoofer applications where very high power levels are required to reproduce extremely low frequencies with ade- quate headroom. Such enclosures usually contain 2 or 4 loudspeakers to handle the power levels involved. For Bridge mode usage, the enclosure impedance must be 4 or 8 ohms. Never below 4 ohms.
bridge irb
interface Dot11Radio0
no ip address
broadcast-key vlan 1 change 45
encryption vlan 1 mode ciphers tkip
ssid cisco
vlan 1
authentication open
wpa-psk ascii 0 cisco123
authentication key-management wpa
ssid ciscowep
vlan 2
authentication open
ssid ciscowpa
vlan 3
authentication open
Step 5 bridge-group number
Example:
Router(config-subif)# bridge-group 1
Assigns a bridge group to the subinterface.
Note When the bridge-group command is
enabled, the following commands are
automatically enabled, and cannot be
disabled. If you disable these commands
you may experience an interruption in
wireless device communication.
Resetting modem to Factory Defaults
Using the tip of a ballpoint pen or unfolded paperclip, press and hold the Reset button located on the bottom of the router. The pwr LED will blink red once, indicating that the reset has begun.
Continue depressing the Reset button for four seconds or until the pwr LED begins to blink alternating red-to-green.
Release the Reset button.
Set to bridged mode
Should now be on http:\\10.0.0.138
Click “Login” option. The “Username” is admin and the “Password” is admin. Then click “OK”.
Click the “Setup” option and then click the “WAN interface” option.
If asked for a Username/Password use admin/admin
Click under VC heading the “8/35? option.
Click “Next>>”
The PPPoE option should be selected and then click “Next>>” again.
Under the heading “PPPoE Type” select the “Bridge only” option and then click “Next>>”.
Click “Finish”
A reboot is required before the new configuration takes effect. Click the word “reboot”. An additional “Reboot” button will be displayed. Click this “Reboot” button”
Need to setup the wireless on your 877W or 857w. use the following sample.. obviously update the SSID and wpa-psk key.
bridge irb
bridge 1 protocol ieee
bridge 1 route ip
no ip address
bridge-group 1
no shut
broadcast-key change 60
encryption mode ciphers tkip
ssid MYSSID
max-associations 10
authentication open
no guest-mode
wpa-psk ascii mywpapskpwd
world-mode dot11d country AU outdoor
speed basic-1.0 basic-2.0 basic-5.5 basic-6.0 basic-9.0 basic-11.0
basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0
channel 2452
station-role root
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
ip virtual-reassembly
ip tcp adjust-mss 1400
bridge-group 1
hold-queue 100 out
interface BVI1
ip address 10.0.0.3 255.255.255.0
ip nat inside
Reset your modem.
There is a reset button on the back.
Push it in and hold it down for thirty seconds with the modem on.
Log into the modem at 192.168.1.1 (admin/password=username/password)
You will need to change the modems administration username/password,
doesn't matter what to since we'll make it unreachable soon enough.
On the connection overview page goto configuration.
Go to DHCP configuration and switch the DHCP server off.
Then goto configuration and click on VC configuration.
All but the first VC should be disabled.
Click on the edit or configure button next to the first and enabled VC.
Switch from either DHCP or PPPoE to Bridge.
At the bottom of the screen click on set VC.
Done.
Your modem is now in 'full bridge' mode and will need to be reset again to get it out.
you can't set teh modem to bridge mode, however, you can set the router to bridge.
The linksys should have bridge mode configuration in the uer guide.
connected the 2 router together
configure the IP address of the liksys to be inthe same subnet as the moem, but out of the range of the DHCP of the modem. ie. DHCP address 192.168.0.2 through 192.169.0.100, the linksys should have the IP address as 192.168.0.200
disable the DHCP on the linksys
setup the wirless just the way you would if ti was the modem.
connect from the modem LAN port to the LAN port on thelinksys. leave the WAN port open.
You could install Router Techs firmware on your modem www.routertech.org and it would give you the option to put the modem in full bridge mode. However I'm not sure the hardware on the modem fully supports it. You might have to use half bridge mode and let your router do the DHCP.
