How to update the map for FineDrive 400?
SOURCE: FineDrive 400: Original SD card got corrupted!
you need to reload the firmware in the unit and reload the map data on the SD card, this will fix your issues. as finedrive is not around anymore, here are the files:
here is the link to the instructions and install data.
http://www.flyupload.com/?fid=951808
install data
http://www.flyupload.com/?fid=6960824
and the map data
http://www.flyupload.com/?fid=9768281
SOURCE: Finedrive 400 reset problems
if you go to the meny and exit at the top left (I think) you will get out to the main menu where under setup you can reset the GPS receiver by itself.
what problem is the unit giving you?
SOURCE: finedrive 350 maps
Yes I do. Please remember when using this device that the mapset it uses is a 2005 mapset and there will be no updates to that mapset.
SOURCE: I have a Finedrive 400
This is a common problem with these units, it happens if the unit is shut off while its writing data to the SD card.
one solution is to visit C&C wireless and pay over $100 for a map update or even send them your unit for even more $. see http://www.finedrive-acc.com/shop.cart?action=ITEM&prod_id=F400-08CP
The other solution was to send it to Fine Digital but they closed their doors in the US so they no longer support us customers. Because of this I made a DVD with map data I purchased from them before they closed and I added much better instructions; this DVD updates the firmware in the unit and loads the last map data issued to the SD card. you would need a PC with a DVD drive and SD card reader to use it. you can find these DVDs on ebay for $18 which basically covers my costs only.
SOURCE: how to update gps finedrive 400
