How can i fix this problem
SOURCE: HP DESKjet 2050 ALL-in-ONE J510 CAN'T GET IT TO
Try to reinstall the driver with your Pc's. Maybe its not properly install.
SOURCE: Necesito descargar e instalar el
try on this page
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=ro&cc=ro&lang=ro&product=4027469&
select your operating system and good luck!
SOURCE: I keep geting the door
hi there!
make sure that the top cover of your hp deskjet is fully closed, open it up again, check for any obstruction then make sure you hear the snap sound when you close it back. if you're in the usa, you can contact 800-hp invent for technical support especially if the printer is still in warranty!
SOURCE: error (0x00000015) while scanning with
See when it comes to scanning problems with the printer ...The first thing to make sure scanning problems don't occur when scanning...... is to have the software for the printer....cause the software is for the scanning feature of the printer... . and the other thing to do is download the scanning utility for the printer ....its found on the company's website under the title drivers and support or drivers and software......Just click on the title and enter the full name (that includes the numbers after the name)of your laptop, printer or any hp product that needs a driver for the pc..... get the right scanning utility for the printer and you will fix the problem...
SOURCE: I need a user manual for HP Deskjet 2050
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=4027469&lang=en&
According to your problem reopen the output try or replace it. Check the settings of the printer. Then reboot the printer and the system both. It will solve your problem.
