Question about Creda Colonial 42352 23 in. Electric Cooktop
Stove top ignition doesn't stop ticking
Our stove top is a CREDA gas/glass cooktop. All of a sudden the ignition switch doesn't stop ticking. It only goes off when we either unplug the power supply or one of the burners (#1) is ignited. If the other burners are ignited it continues ticking.
Posted by maroesteban on
  • vmkhemka Mar 30, 2009
    I have "CREDA" gas cook top also, it 5 burners top.
    I have exactly same problem as yours.
  • LeopoldB Apr 02, 2009
    I have the same problem. Is there any solution????
Anonymous
    New Friend:
My Dacor cooktop had a similar problem of continuously clicking igniters. I unplugged it a couple months ago and used a piezoelectric igniter to get it started. Then I looked in the Dacor FAQ and it said to clean the ceramic igniter posts with alcohol not water. I had to scrape some gunk off a couple of the posts with a knife before cleaning with alcohol. Now it works.'
I think the igniters use electrical conductivity to detect when they need to spark, so even slight invisible contamination on the igniter insulator can confuse the sensing system. Also they all seem to fire as a group, so all of them need to be clean because if any one of them is dirty then they will all malfunction.
Posted on Jan 04, 2010
  • jashurst154 Dec 30, 2010
    Unfortunately this didn't work for me. I thought it made sense, since the problem began after Christmas cooking from several cooks (lots of frying style breakfasts). I had already thoroughly cleaned - even vacuumed beneath the ignition switches. The clicking is driving me crazy!
Middle section ticking sound with sparking as if trying to ignite even though knobs
Try using a pair of pliers and pushing down as you turn first counter clockwise as if you are turning the gas on then back clockwise till it won't turn anymore. If it's still trying to ignite see if its the oven or make sure that its the burner that's trying to ignite . I''m not a appliance person just a home maker so if it were me and none of those things work turn off the gas to the stove unplug the power to the stove and call the gas company or appliance center. One thing though some of those type of knobs are two parts like they have to be pressed down to turn on the gas. Or the have to be set in a certain position to engage the ignite switch. If you know a little about wiring look at the switch and check the wires. But make sure before you do anything that there is no gas on.!!!
Oct 02, 2012 | Fisher and Paykel GC36 Gas Cooktop
The stove is continually ticking - What should I do to stop it?
Hi kayandsky,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 30, 2011 | GE Profile JGP636 Gas Cooktop
My ignition for the gas cooktop is clicking without being in the on positoin. will this be caused by cleaning with water? is it going to cause problems?
One of your burner ignition switches is fried. To see which one it is you remove a wire from each one till the ticking stops. Or plan be just unplug the stove and light it with a match.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 12, 2010 | GE Profile JGP636 Gas Cooktop
Looking for new spare parts Creda Gas cooktop 42320
Contact this gentleman: Sandor Horky [email protected]
He helped us with parts we needed for our CREDA Model GGH110. I believe the company ADCO is the after market people for CREDA. Good Luck. PA Fi.
Mar 12, 2009 | Cooktops
Ignition sparking on its own with GE mongram gas stove top.
the sparking is one of the switches under the knobs shorted you may be able to open the top and take a switch off 1 at a time and you can figure out what one is shorted.or you can just change all of them.
to stop this you may be able to just unplug the cooktop from under the top.if you unplug the cooktop you should be able to light the burners with a match.
Nov 14, 2008 | Cooktops
Gas stovetop burner - continuous clicking
WHEN CLEANING YOUR BURNERS YOU HAVE PROBABLY MOVED THE IRON TOPS-READJUST AND YOU WILL FIND THE CLICKING WILL STOP.
Sep 18, 2008 | Cooktops
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
Open Questions:
Creda Colonial 42352 23 in. Electric Cooktop Logo
2,598 people viewed this question
Top Creda Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Creda Cooktop Expert? Answer questions, earn points and help others
